firstly...why the need for a 'double-framed' locomotive?
surely the actual steam engine chassis layout really isn't relevant......in this case, with the motor in the tender?
however.......for a scottish loco, which perhaps combines both outside and inside loco frames, what about the Allen-designed Goods engines found throughout the Highland Railway system..from the later 1800's, right up to LMS days?
these were of a design type known as the 'CREWE' type....ie although outside cylinders were employed, the cylinder slide bars were combined with an outside frame, leading to a particularly unique appearance.
for a simple model, this design lends itself to simplistic valve gear.......since slide bars, etc are hidden from view.
http://www.lochgormkits.co.uk/html/page_4_locomotives.html
shows a HR Duke class.....but the 2-4-0 Allen Goods engines were what I was particularly thinking of.
http://www.ambaile.org.uk/en/item/photogra...4663&zoom=2
shows a typical example of a very early HR engine....later ones followed a similar design pattern, but more 'updated' fittings, etc...
http://www.ambaile.org.uk/en/item/photogra...4281&zoom=2
again as above.....
regarding tender-mounted motors?
The ideal method is to step-down the driveline from the motor, to lower the driveshaft line.......this reduces the torque reaction effect.also might place the driveshaft below the cab floor.
around curves there ought to be few issues.....after all, this is the sort of drive associated with better quality diesel mechanisms?
the secret is the placing of either the universal joints, or the flexibility of the driveline.
It IS a widely used system [in the past] when small motors were harder to come by.
I also suggest looking at the tender-loco connection.........cantilevering the tender body [and motor] off the back of the loco chassis increases adhesive weight. [ie, the front of the tender chassis is separate from the main tender body, which is supported at its rear on the tender chassis, and at its front, off the loco coupling.]
Your main problem will be the gearbox arrangement.
are you using the O-4-o chassis in some way?
or just a spare motor from one?
whatever, try to maintain as straight a driveline as possible, motor-to- engine gearbox..
