21 - 31 of 31 Posts
QUOTE The points are live electro-frog points and with those, you have to isolate the frog rails. You have to also provide power behind the isolated frog rails
Agreed that you have to isolate the frog rails when electro-frog points are used. I don't recall any mention by anybody of Electro-frog points in this thread though.
Are Electro-frog points being used by those making the enquiry?
Happy modelling
Gary
If standard Hornby points are being used then one power clip on the outside oval and the Hornby spring clips mentioned above inserted into all the Hornby points should be all you need to electrify the whole layout for Hornby digital. Thats what Hornby seem to say anyway. You should remove all the power clips you currently have and insert the special Hornby digital power clip on the outside oval. This is designed to take the constant load of DCC power of the 4 amp power supply and does not have any capacitor fitted. Make sure all your fishplates are tight and that all points have a good electrical contact.
How many Hornby points do you have and do you have any areas currently isolated for standard DC?
And do you only have Hornby points?
If the answers is only Hornby points, not more than say 10 or 12 and no isolated sections then to be very honest I would try out what Hornby say initially and if that works for you then fantastic. Ok the Select power pack is 1 amp and this can limit you to have 3 locos moving at a time. You can always upgrade to the 4 amp power pack if you want to have up to 10 locos moving at a time.
If you want to get a soldering iron out to hard wire things then this will definitely improve the flow of current around the track and this can be done after the above if need be.
In terms of a small layout thats completely Hornby its best to stick with what Hornby say using the appropriate Hornby bits and bobs. Just remember that power is on 100% of the time throughout the entire layout which is a little different to normal DC operations.
If you find you have a hiccup then come back.
Happy modelling
Gary
Discussion Starter · #24 ·
QUOTE (Gary @ 11 Dec 2006, 14:15) <{POST_SNAPBACK}>How many Hornby points do you have and do you have any areas currently isolated for standard DC?
I have about 10 points on the layout, for mainlines and sidings.
Sorry, im new to all this electrical jargon; what do you mean by 'isolated for standard DC'?
Thanks,
Ed
QUOTE Sorry, im new to all this electrical jargon; what do you mean by 'isolated for standard DC'?
Sorry to use jargon. Don't worry about it. If you had done it you would know what it was so clearly you haven't.
You might have a section of track that you can switch the power on and off to that is not electrically linked to the rest of the layout. I don't think you have from what you are saying.
Happy modelling
Gary
Discussion Starter · #27 ·
Thanks very much for all your help guys, really appreciate it!
It looks like i'll give DCC a try this Christmas - I'll let you know if i encounter any further problems.
Thanks again!
Now that could not be any easier. All those thinking of a Hornby digital Xmas should commit the schematic below to memory. Hornby should pop Doug's diagram on their website! Keep that for future reference Doug as it may be needed again:-
Has the decoder question that started this off been answered?
Happy modelling
Gary
Discussion Starter · #29 ·
QUOTE (Doug @ 11 Dec 2006, 15:24) <{POST_SNAPBACK}>Here is a track schematic plan to use when you use the Hornby points with connector clips (wire pack R8201).
So just to clarify:
I could, if i want, just use the R8232 Hornby DCC Electric Point Clips - instead of the link wires - to get the current flowing to all parts of the line, via the points?
· DT
QUOTE (edzmen @ 11 Dec 2006, 18:00) <{POST_SNAPBACK}>So just to clarify:
Yes.
Later on, you may find your point blades get dirty and cause a bad circuit. This is why we install BUS wires that help guarantee a clean circuit throughout the layout. Take a look at the DCC Jagon buster for more info.
21 - 31 of 31 Posts
