Norm's Loft Layout
103864 Views 755 Replies 61 Participants Last post by  Norman Byrne
Hi All,
Well here goes my first post on my WIP Loft OO guage model railway.
Having been away from the hobby for longer than I would care to mention, but its well into double figures, I decided a year or two ago, to sort out the loft & try to find all the boxes which have not seen the light of day since we moved to West Sussex over 13 years ago, & have another go at a hobby which I have loved since childhood in the 60's.
Well that took care of most of the 1st year ! Sorting the loft, clearing it sufficiently to be able to move, installing some velux rooflights & having the water tanks moved, to avoid them being a central island; then insulating & lining the loft with plastic sheeting & hardboard - were a few occassions I have to say when I thought am I sure I want to be doing this LOL !
Anyway in parallel to the "muck & bullets" prep. works in the loft, many an evening was spent scribbling possible plans, scouring the railway modelling press (* forgot to say I had built up a collection of about ten years worth of Railway Modeller still in the plastic wrappers, which were also found in the loft - lots of copies still to open / read !) & starting to visit a few local railway exhibitions / shows, including Worthing, Brighton & Chichester,to both get ideas & also try to play catch up on how the world of model railways had moved on during my "gap decade" - what on earth is this DCC thing; how can they have trains double headed, & numerous trains on the same track !!!!! What a learning curve I still have to climb.
Well eventually got to the stage that baseboards could be assembed / built, & plumbed for the more traditional 6mm marine ply solid deck, on the basis I could build upwards from that, with a timber softwood framework below. The loft space being rectangular about 18 feet x 6ft 6 based on a baseboard bottom level about 2ft 6 / stool / chair height off the ground, was what I had to paly with - seem like a lot to me !!! Big problem obviously being tight curves at each end, as I did want to be able to "watch the trains go round" to some extent at least - you have to relax sometime eh ?
Well having now built the baseboards (* hopefully see pics below), I then after much grey matter scratching opted for DC (* I can hear the groans now !!!), as I was keen to be able to run my old engines which I have accumulated over the last 40 years or so; also its what I thought I might remember (eventually). I also opted for Peco code 100 track & electrofrog points. As in the dim & distant past always had better running over that type of point.
So thats enough of the the history lesson, but just wanted to set the scene. I have now progressed quite a bit of track laying, which I have done on a cork base, generally one layer over the complete ply baseboards & then a second layer under the tracks themselves. Have added a few inclines to link some upper level sections, & also some hidden loops behind some demountable retaining walls, the current finish on which needs a lot of development - but thats on the to do list, or should that be to do "roll" !
Have hopefully attached a couple of overall pics of the loft as it currently stands, & look forward to using the knowledge of others & learning my way back into this great hobby, with the assistance of other members on this forum. Happy railway modelling & Cheers for now,
Norm
PS. Will try to add some pics a little later - after lesson 2 LOL !
PPS . Have added a few pics in an album, but cannot seem to get them on here - must try harder LOL !
681 - 700 of 756 Posts
Hi again All,
Came across a couple of steam cranes in a tandem lift, as shown below, looks like a heart in the mouth moment for sure ....
May not attempt this on the MR, perhaps something more along the bridge / infrastructure lines in terms of a static model !
Happy Modelling, Cheers for now Norm
Hi Norm,
Reminded me I had this tucked away
  • Like
Reactions: 3
Hi Alan,
That’s a really nice video and that Märklin Steam Crane is certianly a seriously lovely piece of kit.
Did you motorise the jib, lifting block and rotating crane movements yourself, over and above what it comes DCC fitted with operationally - as overall makes a really interesting and detailed model. (* ⭐ on the couple of video continuity edits too).
Thanks for posting Cheers Norm
Hi again All,
Thanks as always for your positive comments on the recent posts.
Having done a little research on the likely make Ups / formations of an Engineers Steam Crane Train. In addition to the normal old carriage mess room / travel coach; tool wagon / converted brake van and often an open wagon, it seems an old tanker / milk wagon was often also included to provide water for the Steam Crane; this being a milk tanker, marked up “Not for Milk Use” or words to that effect.
Cheers for now, Happy Modelling, Norm
PS - There is a 2010 previous Thread With some very informative info on this started by Lettoll - Breakdown crane
  • Like
Reactions: 1
Hi again All,
Sure we all have projects for the BH Weekend, a revisit / more progress on the previously posted “High Level Signal Box” is certainly one here -
Property Product Interior design Art Font
.... early days / thoughts and only using a couple of Metcalfe kits as the existing, but aiming for far more windows / vision in both directions at least to start with .... more to follow as always .....
Comments / Input always welcome, also a maker of the PappaP box perhaps ?
Thanks as always, Cheers Norm
  • Like
Reactions: 2
Hi Alan,
Hi Norm,
Thanks for your comments. this is the Trix 23057 steam crane and comes fully dcc operational . The only downside was that the instructions state the hook should not be lowered without "load" for fear of tangling the cables (hence at least one of the video continuity edits). I doubted this was prototypical and didn't like the operational restraints, so I cut and shaped some thin self adhesive lead strip, applied it to each side of the hook and painted it to match, this gives me the "invisible" weight to allow unladen lowering. Also, being self adhesive, it can be removed without damaging the original model
  • Like
Reactions: 3
Hi again All,
If you haven't seen it, the old Clapham Junction A signal box may provide some inspiration. https://signalbox.org/photo-gallery/london-south-western-railway/clapham-junction-a/
  • Like
Reactions: 1
Hi Cameron,
Many thanks for posting that link to the Clapham Junction “A” signal box - some stunning pics and information is included; but also the link overall which makes a really interesting read and holds lots of great reference information too.
Cheers for now, Norm
  • Like
Reactions: 1
Hi again All,
Further to previous post (#683) in relation to the possible make up of the Steam Crane Train, have been putting a few items together here, which currently have available, hence a bit of a mixture, but mainly as food for thought, as Initial pics below (pics may be better this evening);
Overall Views -
Plant Asphalt Road surface Grass Automotive exterior
Window Automotive exterior Mode of transport Vehicle door Vehicle
Window Mode of transport Wood Bumper Floor
.... will need to add a Loco too of course. Also adjust / lower the Crane jib for travelling !
A Few Close Ups -
Wood Office supplies Office equipment Flooring Floor
Plant Wood Shade Tints and shades Roof
Wood Office equipment Flooring Bumper Hardwood
More to follow later .... Happy Modelling, Cheers Norm
  • Like
Reactions: 1
Hi again All,
Further to the above post, was thinking of Steam Loco wise, perhaps using some of the following -
Trigger Air gun Gun barrel Shotgun Machine gun
Train Vehicle Rolling stock Steam engine Railway
Train Vehicle Rolling stock Toy Wheel
With either a Southern or GWR flavour too.
..... will also look at a Diesel option / alternative too.
As always any thoughts / input appreciated.
Hi All,
Well thinking time again, WIP pic - given all the great links / pics, working on the attached, at the moment (stop gap or step forward); but also don’t know why never thought about previously (wood from trees perhaps); if all the support structure was painted black from grey too, might be a step forward ......
Vehicle Font Rectangle Wood Automotive design
.... it’s all fun eh 🤔
Enjoy your Railway Modelling, Cheers Norm
  • Like
Reactions: 1
Hi Norm If you are going to build from scratch or utilize a kit/kits are you going for loosely based ,generic or a more accurate model ? I noticed that you have a mixture of buildings and stock, engines from different companies so is it rule one applies or do you have a theme? . For myself it is GWR but I wouldn't rule running anything else out either on an anything goes day. Jim
Hexham signal box. I lifted this from Wikipedia. This is subject to Creative Commons, attributed to Mike Quinn.
Best regards ................. Greyvoices (alias John)
  • Like
Reactions: 1
Hi Jim,
Thanks for your reply / post. Plan is “short term” to use the Metcalfe kits matching the existing, but on an extended model version, as in Progress Pics above and below. Plus make other alterations as a further progress step hopefully, to the existing Gantry Signal Box ....time will tell as always.
However, would ultimately like to find a more prototypical model source - along the lines of your posted images and Greyvoices image today perhaps. That level of modelling is beyond my skill set however !
In terms of setting / region / etc - in the main also have GWR and Southern stock, and would envisage a location where these regions cross overall.
But have over 50 years plus, collected a wide range of other models too and am as yourself, happy at times to run them 😉.
Ps. Hope you are making progress on the new layout too.
Hi John,
Many thanks for the post / image of the high level Hexham Signal Box - another great pic - also “in an unusual” colour scheme too (* that may just be me of course 🤣).
As post / reply above and to follow, am working on a “further hopefully short term step forward / development” and then see what the future holds perhaps.
Thanks as always for your comments / input; Cheers for now, Norm
Hi again All,
Further to the last couple of reply’s above, and the previous WIP pics / updates on the gantry Signal boxes latest developments, a few current pics below, still plenty to do of course;
Building Urban design Wood Art Rectangle
Wood Art Floor Flooring Publication
Window Building Wood Road surface Asphalt
....... next to place it on the existing gantry (* prior to gantry mods / repaint too); just to see how it looks .....
Happy Modelling as always, Cheers Norm
  • Like
Reactions: 2
Hi Norm I had a brief look for GWR over rail signal boxes and as yet to find an example. Barton street box was of course a Midland box so potentially a bit of modellers licence . Although the picture you have is a later one there were three or four semaphore signals mounted on the gantry as the box also controlled the Southern end of Eastgate station as well as the road crossing. On Friday I went to the Bristol railway model show which funnily is not in Bristol but up the road in Thornbury. Amongst the layouts and the usual stands were a few stalls with people selling laser cutting buildings ect. and also 3D printing with some very nice products. Some of these do commissions but I should imagine they would be expensive, for me they did some low relief warehouses or factories which I thought quite reasonable.
The Hexham box looks interesting as well is it up near Newcastle and did it also have signals on it's gantry ?
Re my layout not much to show I have laid all the underlay on the storage side and just started laying the track when I have completed storage trackwork I will post some more pictures. Jim
  • Like
  • Helpful
Reactions: 2
Hi again All,
Having a further look through the Signal Box link / site from which Cameron posted previously for Clapham Junction Box “A”; came across the following for Canterbury West box, which is an elevated gantry box straddling the tracks, as against running parallel to the tracks - the website has plenty of very interesting photos and detailed information overall -
https://upload.wikimedia.org/wikipedia/commons/f/f7/Canterbury_West_Station_Signal_Box,_Edit_1.jpg
Train Sky Plant Rolling stock Track
Also a further associated link is the following -
..... well worth a look through / read.
Enjoy, Thanks for now, Cheers Norm
Hi Jim,
Thanks for the further post / input (#696), hope it was an interesting exhibition visit, had seen it being advertised.
The 3D printing and Laser cut buildings inc bespoke / commissions also sounds interesting - do you have any contact details maybe ? Are the low relief units you have for your new layout ? Might email them with some signal box images to get an idea on budgets to start off with at least.
Thanks also for taking a look for further high level / over track signal boxes too - as post above have found some further interesting links and a video too !
On the Hexham box front and any signals being attached too it, am not sure tbh - found a few more photos, but similar to Greyvoices image post, with no signals visible.
Good luck with continued progress on your layout and the track laying too - a key aspect not to be rushed for sure. Look forward to photos once reach that stage.
Hi All,
Well cop today -
Wood Automotive design Urban design Art Font
... just need to get into the loft to see what might fit or not as the case may be, ..... but step by step always;
Enjoy your Modelling in the meantime, Cheers Norm
I really like that Canterbury signal box Norm. It looks a perfect match for your kit. The framework structure looks very easy to replicate by use of Plastruct. A quick search came up with this link one of many firms selling Plastruct and I suppose it can also be found on ebay.
Font Rectangle Line Parallel Clock
The main problem with elevated signal cabins was linking the cabin levers with the linkage to the signals. If you are modelling the semaphore era then you need to show rods or wires coming out of the cabin, feeding into cranks on the ground. No so difficult. Of course in the colour light signalling scenario it becomes much easier for you just have to replicate a cable duct or shaft.
The Hexham box is easier because one side is supported by a brick structure which presumably has linkages running vertically through it. If you go the Canterbury route (which I prefer) you could support one end with a brick structure but then would miss out on the joy of seeing all those linkages on display.
I really like this box. Easily achievable with Plastruct though others might suggest alternative methods of construction. I remember an old Airfix kit signal gantry which may be of some transferable use. Still may be in the Dapol range.
Best regards .......... Greyvoices (alias John)
  • Like
Reactions: 1
