QUOTE .Didnt Wrenn make card/fibre track at one time in 00.I seem to recall it had a far better sleeper spacing than Peco.
well...no it didn't, really.
the sleepers were incredibly wide..the rail was more like code 1000...would have done nicely for O gauge.....and hte fibre bases de-laminated quickly if wet....also very hard to curve...block and tackle stuff.
not the favourite fibre base trackage...GEM was better.....peco also did fibre-based , spiked trackage.....
Wrenn trackage also had some quite unprototypical pointwork...didn't have a crossing as such if I remember rightly.....the whole point blade and crossing pivotted, so when the blade end contacted the stockrail, the other end which included the wing rail, closed up on the crossing vee.....a bit like a prototype diamond crossing whose angle is so shallow, it has a switched crossing, since otherwise the gap between vee and point rail would be too large. [yep, there is a max crossing angle before a swithced crossing is used]
I,too, like jimread's card sleeper track...why not? I have left sheets of cheapo thin ply [packing case] outsdie for months.....just to get the veneers to separate...nice and thin...but a booger to cut neatly.....card seems better.....less domestic grief about mouldy old wood that needs binning?
If one happens into an office...check out old redundant file cards...bit like postcard,and no-one wants it.....
