41 - 42 of 42 Posts
Discussion Starter · #41 ·
Judging by my response time on this thread you'll recieve your answer in four to five months.
Mine has not been run enough to notice any problems so I could'nt advise apart from a clean up.
cheers Frame.
QUOTE (jimread @ 1 Feb 2009, 23:07) <{POST_SNAPBACK}>Dear Frame69,
You would be very welcome to the drawing I made and I would make a close up pic of a point for you so that you could see how they are made.
Dear Rossi,
Shellac has the same effect as does PVA glue when laying ballast I changed my mind about my layout and am now making a 3 way point plus 1 LH and 1 RH to make a crosover between 3 tracks, I had to scrape up the track I'd previously stuck down and ballasted, it was tough :)
Jim
I've also found Shellac an interesting material - an easy option to obtain is knotting from DIY shops, which. I think, is, or used to be, shellac diluted with a solvent. I've found using knotting on card models (I've only made buildings, not sleepers with it), results in a very durable strong material.
Robert
41 - 42 of 42 Posts
