1 - 20 of 25 Posts
Hi, I like to share my last model build, is a kit from spanish company OcCre
http://catalog.occre.com/modelismo-ferroviario.html
kit is made in metal castings, wood and brass plates.
it is long 720mm and it weight 3kg in running order.
I have set my locomotive with 2wd motor unit sold separately
my locomotive is radio controlled, it have smoke unit, speed controller and 3s lipo.
now I show you how I do it..
sorry for my poor english, I do my best to answer your question
Discussion Starter · #2 ·
first step I have built the bolier..
I have bend brass plates using a iron cylinder ad a bottle as to obtain the right radius curve
then I have glued metal castings with Uhu plus 300+ endfest
I have drill bracket fusion as to pass wires inside
where possible I have soldered
windows are in real glass
now the mistake and 2 versions of smoke unit..
in first I put smoke unit in the tender because was not in my hand when I had built the boiler..
it cross all the train to the tender.. 40cm distance.
but the smoke was not enough
then I arm myself with a great dose of courage for a very intrusive modify
now smoke is great.. I just have to set it proprotional with forward.
front casting now is openable
· Oldbiker
Brilliant, after building an “O” gauge model of a straight boiler Scott class (royal Scot) steam locomotive in O gauge, I can appreciate the amount of work involved and the great standard you have achieved.... well done 👍
Wow. That's quite something!
Discussion Starter · #13 ·
now I'm doing the indoor railway
I have to do two long curves as to finish my track.
it is comparable with R3 rail.. 2 meter diameter
first locomotive test it slipper much, reverse run was impossibile.
as to solve situation I have mould an heavy ballast lead plate.
and this is my last run test
that's all for now
today postimage has broken his site .org
so I have no way to edit photos and chance .org with .cc otherwise photos will be visible..
if a moderator want to edit my posts is easy to chance .org with .cc
this is the message they give:
postimg.ORG domain is locked by Registry, no prior notice.
While we hope to resolve the issue, we chose postimg.CC as our new home.
Please update codes embedded in your websites.
so here edit is bloked and I have no way to solve by myself.. the only thing I can do is give to you the new adress gallery of this locomotive and I hope it's only a temporary problem
https://postimg.cc/gallery/tv277240/
· Chief Nut Maker
QUOTE (christian Wright @ 5 Apr 2018, 20:24) <{POST_SNAPBACK}>now I'm doing the indoor railway
that's all for now
Discussion Starter · #17 ·
QUOTE (christian Wright @ 5 Apr 2018, 13:40) <{POST_SNAPBACK}>first step I have built the bolier..
thanks
1 - 20 of 25 Posts
