On Neils workbench
21065 Views 133 Replies 27 Participants Last post by  madon37s
21
I haven't bothered doing a workbench thread before as I intended putting most of this sort of thing in my blog. I'm not sure the blogs are that widely known about and some of the stuff I've been working on may be of interest to a wider audience so I thought I would also do a workbench thread.
One thing I have been doing quite a lot of is using plasterboard as a medium for cliffs, walls etc. It has the benefit of giving a more authetic appearance than paper or plastic and in my case, being free; sort of.
While renovating my garage I used a substantial amount of plasterboard and was left with a fair bit as I had over ordered which I had initially intended to chuck, but was advised strongly against doing at the time by my father in law who cited various DIY projects where it could be used. I had been doing a fair amount scenery building with plaster and it dawned on me that the same brick/rock effect would obviously be available from plaster on plaster board as it would on plaster. I had a fair amount of rock cuttings to do and thought that as many of them would be cuttings as opposed to cliffs that I could use the plasterboard to make these.
The plasterboard modelling process is pretty straightforward. I would recommend doing this outside and over a bin if you can. You may wish to use a mask and goggles as this is very messy.
The section of plasterboard cut to size.
Insert stanley knife or screwdriver between the card covers into the plasterboard.
Prise away the plaster on one side.
Continue to remove all of the paper from one side of the plasterboard leaving the other to maintain structural integrity. I initially used a screwdriver but this is incredibly slow and found a Stanley knife far quicker. By wedging the knife in the side and twisting a shattered rock effect can be gained while removing the paper. Once all the paper is removed from one side you can use a screwdriver to add more effects to make it look more like shattered rock.
Once the paper is removed, a series of coloured washes can then be applied to resemble the rock of your choice. For the first coat I used a matt enamel type paint diluted with turps to seal the plaster. The colour to choose depends on what type of rock you are after, white for chalk, grey for Oolitic Limestone, beige for Portland Limestone, red for Central Scottish sandstone. You really don't want any dust getting onto the tracks or into the inner workings of your locos. For subsequent coats you can weather the rock face or add other colouring to resemble the type of rock you are trying to represent, e.g. spots of pinks or whites for granites.
This is the sheet when placed in position on a slope. If you are using water based stains for the secondary coats it is best to do this on a warm day or in a heated room as you want the plaster to dry quickly and not absorb the water. I tend to use several layers of washes to build up the weathered look. I have a large container of stain wash which I apply every time I am out there to build up the layers.
And with a bit of scenicing.
Plasterboard would also be ideal for making brick walls too however once you have removed the surface paper lining you will have to level the surface again by sanding it flat. It may be easier to apply plaster to the surface you intend to look like wall than to do this however it does offer one major advantage; it is difficult to line and etch the plastered surface while it is attached to a structure on your layout. It is comparatively easy to work with a sheet of a foot or so of plasterboard and to etch lines into it with a modelling knife and steel rule. There is also the ability to "point" the brickwork which is best done on a flat surface.
As before the first step is to strip the paper from one side leaving the paper intact on the other to preserve structural integrity.
Having done a fair bit of this over the last month I have found that you now want to file the stripped surface flat if you want an even new build sort of finish. If you do not then leave it uneven and it will represent older crumbling brickwork. The next stage is to use a steel rule to etch the brick work effect into the plasterboard.
The vertical lines have to be done by hand and yes, this is very time consuming.
Next step is to give it a colour wash with your choice of brick colour thinned with turps. I then add subsequent layes of water based washes to weather.
These are added in the form of tiles one by one to make up the area required. Joins can be disguised, if not tight fitting, by buttresses or weeds.
These are all attached with PVA glue. The ends and buttresses can be easily made up from small offcuts.
Here are some pictures after scenicing has been applied to the brickwork.
In conclusion it is a lot of work but is worth it for the authentic effect. It's probably better for stone than brick as bricks are pretty small in HO/OO scales. Here are some more pictures of structures I have made using this technique.
41 - 60 of 134 Posts
QUOTE (BRITHO @ 28 Jul 2008, 16:55) <{POST_SNAPBACK}>Looks really good Neil - almost good enough to drink in!
Or outside if you smoke
QUOTE (Brian Considine @ 29 Jul 2008, 02:30) <{POST_SNAPBACK}>Or outside if you smoke
Actually outside is great in summer. The benches overlook Elie harbour.
QUOTE (neil_s_wood @ 28 Jul 2008, 22:29) <{POST_SNAPBACK}>Actually outside is great in summer. The benches overlook Elie harbour.
It certainly looks idyllic Neil, I assume it is in the Highlands and Islands somewhere.
Great work there Neil
Can't wait to see this one on the layout
If you think you've learnt things whilst makingthis Pub, the next one will have me queing outside trying to get in
Andii
QUOTE (alastairq @ 30 Jul 2008, 02:21) <{POST_SNAPBACK}>
is it on the right?
Yes, third building in. Well spotted.
Dave this is in Fife which is not far north of Edinburgh.
Andii, I have to say I really did fancy a pint after making this.
Hi Neil ,
The pub is very impressive it looks like it has been there for centuries -sits in a treat .(What is the pubs name?)
I like the MG outside looks like a TF. ( It rolls back the clock to about 1955?)
Very nice indeed, Best wishes, Tony .
Looks really good there Neil - the whole scene is simply stunning.
Stunning Neil
The whole thing looks great, you've done one of the best jobs of blending the model and backscene I've ever seen. Did you paint that backscene or buy it some where? it's great!
You've got a lovely summers day at the coast with a nice calm sea, but where's the railway?
I love the RIBs though I wouldn't fancy dragging them up that slipway.
Andii
QUOTE (10001 @ 5 Aug 2008, 08:10) <{POST_SNAPBACK}>Hi Neil ,
Hi Tony
It's The Ship Inn at Elie. Look it up on google. They play cricket on the harbour sand when the tide's out. There's a B&B next door. Too popular on sunny summer weekends, though, but a nice trip from Edinburgh.
mal
QUOTE (neil_s_wood @ 5 Aug 2008, 07:42) <{POST_SNAPBACK}>Here's the pub in its new home.
And excellent it looks too! That really does look convincing Neil
QUOTE (Purley Oaks @ 5 Aug 2008, 09:49) <{POST_SNAPBACK}>It's The Ship Inn at Elie. Look it up on google. They play cricket on the harbour sand when the tide's out.
I once played cricket on the Goodwin Sands - in the good old days of the SRN-4s
Lovely job Neil
QUOTE like the MG outside looks like a TF. ( It rolls back the clock to about 1955?)
by the hood shape it looks more like a Morgan......especially with the tan colour and shiny wheels.....which, along with the rubber dinghies on the slipway.....puts the time frame at.....2008?
vey nice job you've done there......like the harbour water....is it a car park when the tide's out?
QUOTE (5696Arethusa @ 5 Aug 2008, 19:41) <{POST_SNAPBACK}>Stunning Neil
Andii
The backscene is a combination of painted sky and photograph. I wrote a bit about this in my blog this month.
The buildings etc are from Crail in Fife. The railway is just to the left. There's a large viaduct just to the left of the Railway Inn.
I've got a Unimog for towing the RIB's up the ramp.
Thanks for the kind comments guys.
I'm not sure if the car is a Morgan or an MG. I have lost the box a while back but I think it's a Morgan. Couldn't swear to it though.
You wouldn't believe what's been parked in that harbour at times Alastair, lighthouses, pubs as well as cars. It serves as my scnic dump when I am doing work on this part of the layout.
The backscenes are really blended in nicely Neil - like the conservatory on the back of the building - nice touch.
QUOTE (Brian Considine @ 6 Aug 2008, 09:46) <{POST_SNAPBACK}>- like the conservatory on the back of the building - nice touch.
Is it the Wills one? I have to agree with Brian though it is something you rarely see modelled.
QUOTE (BRITHO @ 7 Aug 2008, 01:20) <{POST_SNAPBACK}>Is it the Wills one? I have to agree with Brian though it is something you rarely see modelled.
Cheers guys, it's the Langley one. It's quite a nice kit too.
While I was on the BRMA stand at Caulfield last Saturday I was deomstrating weathering models. I took some old style private owner wagons and some new ESW ones too for a bit of variety. I started to add the coal while I was there but I was making a hell of a mess and thought I'd betteer wait until I got home. Here are the results below.
After adding coal to all these wagons I thought I'd better add some to the tender on the loco too. The pretendy coal load in the 9f is very plasticy looking so it had to go.
The modern image ones came out quite well too however I ran out of coal after three thrall's. They take a fair amount to fill. ..and yes I did fill them up with polystyrene first.
The trouble with weathering is that once you start you pretty much have to do everything. I will have to do my Class 66 next and then gradually everything else.
Absolutely brilliant photos, really remarkable the amount of detail you've been able to put together! The real thing must be so inspiring as well!
