QUOTE (upnick @ 24 Oct 2008, 18:16)
<{POST_SNAPBACK}>With the two paints i would definatley avoid cellulose even if a colour is only available in cellulose,
1. Its horrid to use especially in a confined space (garage etc )
2. More importantly if a good undercoat is not applied well or not at all the paint will most certainly attack plastic .... all looks well once its
finished painting but in the morning a melted loco body will result.
Far better either enamel applied over a good undercoat or low odour water based paints ...... i use polly scale they give great cover and of course clean up is good being water based.
A note on using any paint though make sure your using the right type of thinner in an airbrush as the other night amongst my water colour paint i had put a jar needing thinner adding water to it only resulted in a blocked airbrush
The plus point was i soaked all the components of the airbrush in white spirit overnight and now it sprays even better
*** Nick, cellulose and 2 pack are fine on brass and metal loco bodies or coach bodies where it is used... in fact it is far superior in surface finish potential that it knocks enamels and acrylics for six... Its real blessing is the fact that nothing will harm it once its gone off so lining with a bow pen becomes a lot "safer" than when you are doing enamel on enamel.
However its not easy to use and as with anything the trick is to really learn about and understand the paints and their differences - for example, the modellers habit is to apply undercoat then wait for a long time before applying top coats - among other things with 2 pack the top coat should be applied immediately the undercoat has tacked (within 20 minutes of applying undercoat!). Imperfections are rubbed down in the top coat just like with a car!
Smells are all part of the game with painting - almost everything I use smells explosive
Re white spirit, I most often spray with enamels as its easier, so I actually clean the airbrush then re-attach a bottle of white spirit to it and leave it there permanently between spray jobs - the constant presence of the white spirit in the airbrush stops any bit I missed while cleaning hardening too much so its always easy to clean off.
Poly S is fine for US prototypes... however I really still prefer enamels and the "harder surface finish" paints. I'm experimenting with a couple of the other brand acrylics now - they all seem to spray well, but a few things need to be done very differently to get the quality of finish I like.
