Hi. Has anyone successfully modified Peco On30 electrofrog points without melting much of the plastic that it attached to the rail? There are many excellent on-line and magazine articles demonstrating how to convert live frog '00' and 'O' points, crossings etc., but the Peco On30 points have not been engineered in a similar fashion as the '00' and 'O' items and I could not find one demo on On30 points specifically. There is no added wire at the frog to attach a feed wire to, and the frog and rails nearby are surrounded by plastic underneath. I have considered purchasing a small spot welding device to allow me to attach fine wire to the rails as done by Peco at the factory, but not sure if the wire will connect successfully. On-line demos (non model railway) have shown that some small spot welding devices may not provide a permanent weld for the wire.
I do not wish to rely on the very small contacts on the switch blades, and adding extra wire to the closure rails and corresponding stock rails shouldn't be a problem as there is sufficient room between the On30 sleepers after making a cut to the plastic web underneath. I wrote to Peco a few weeks ago requesting advice, but have not heard back to date. I fully realize that they are very busy trying to keep up with production, so I wonder if any members on this forum have any suggestions so that the moderately expensive points don't end up as a ball of plastic with nickel silver rail attached? I am confident with the use of a soldering iron, and have regular 60/40 and lower temperature melt solder plus necessary clip on heat sinks for electronic use in my tool box, along with a number of iron tips. However the very limited space - due to the the point construction - may make things difficult.
Cheers, EW
Cheers, EW
