Peco rolling out 1:120 TT track
3217 Views 13 Replies 7 Participants Last post by  34C
Question that's very obvious: are there any manufacturers lined up to make the stuff to run on this track? Unlikely that Peco would be launching a track range without this in place.
  • Like
Reactions: 1
1 - 14 of 14 Posts
Well there is nothing else to be sure, this is Peco striking out, now 3 mm to 1 foot is a good size and modern technology would make it work better than back in 1965, however who else will bother? right now is in my view not the time, disposable income is being mopped up energy bills, fuel costs, general inflation, and all the rest and most people are already invested in something or other in my case both OO9 and OO so I just do not see a completely different system taking off right now, brave move and good luck of course sums it up.
ps what mm to the foot is this cannot be bothered to work it out myself?
TT is quite popular in the Europe but a quick visit to MSL shows that while Roco and Piko both have a reasonable range of models, neither makes track for it. From catalogue listing size, Tillig look to be the leaders in TT with a large track range.
MSL sell Peco but as you look through the long list of gauges available, TT is absent.
Maybe Peco see a gap in the market for a second supplier?
So here's a question. Is Peco's track more British in its sleeper spacings etc than the Streamline stuff?
And the answer to Kris's question is 2.5mm to the foot so the 12mm is 4' 6".
Yeah I stirred myself and it comes out at 2.541666666 recurring obviously a catchy gauge but I cannot of think of anything made to this scale?
Have read that Gaugemaster are linked with a Class 66 in 1:120 TT; no doubt an existing European model
My thoughts on this:
Peco will obviously be privvy to the figures of how well their 2mm scale products sell. I suspect that given their models are not up to the standard of Bachmann and Dapol, they probably aren't doing that well.
Triang never supported TT3 seriously. It was not to the international standard introduced in 1945. Peco will know how well their 12mm gauge track is selling in the USA and Europe. I suspect they are trying to improve their sales in the UK.
TT3 was a coarse scale. In today's environment with better standards and highly detailed models it could be an attractive option, indeed, my observation of it at exhibitions is that it seems to be very much the realm of 'high standards' modelling due to the need to build everything as a result of no RTR.
Modellers everywhere are always short of space. The popular idea for a solution is to work in a smaller scale. I don't go along with that idea. Someone once said "If you are short of space consider O Gauge". O Gauge is very much "Less is more", although I think many would not agree. TT has the edge on OO for space without the loss of detail that comes with 2mm scale.
True track gauge in 120 scale is 11.9583333mm, an error of 0.04 of a mm or 0.35%. So it well and truly overcomes the "better track" argument. It is better than both OO and O gauge in that respect.
If they can get this close to the correct track gauge in TT then it demonstrates that there is absolutely no excuse why they cannot mass produce P4 !
Good luck to Peco. This could solve a lot of peoples' problems.
  • Like
Reactions: 2
...True track gauge in 120 scale is 11.9583333mm, an error of 0.04 of a mm or 0.35%. So it well and truly overcomes the "better track" argument. It is better than both OO and O gauge in that respect.
If they can get this close to the correct track gauge in TT then it demonstrates that there is absolutely no excuse why they cannot mass produce P4 !...
As I am sure you recognise the barrier to a true scale 4mm is not technical. It's about space requirement. That's why we have HO mechanisms in OO models.
If some brand had been brave back in 1990 with the fixed link to HO-land opening, and had launched contemporary D+E models in HO, by now we would have no scale/gauge problem in UK RTR modelling, fior the period since steam was withdrawn. UK HO D+E will work just as well as all the rest of the world's HO D+E.
The recidivists like myself wanting steam, would still be in OO if using RTR. All the UK's narrow width dimension, thus less space for outside valve gear, and close fitting splashers on driving wheels limitations, which forced the OO compromise will equally apply to 1:120 TT.
This makes the choices for anyone venturing steam models in TT 'interesting'. Might it be the case that those wanting Walschaerts gear pacifics and similar size locos are told 600mm minimum radius, or some similar figure? That would enable correct exterior appearance, no need for the 'vari-scale' approach of stretching the width dimension. With a new introduction, it should be possible to 'reset' minimum radius expectations. (Your inside cylinder 0-6-0 will be quite happy on 200mm radius or thereabouts, so the choice lies with the layout builder - compact curves = small locos - if you want a main line with big engines then much larger radii are necessary.)
The reason we have HO mechanisms in OO model is because the thicknesses of plastics and size/strength of valvegear is such that it is difficult to make them strong enough if the mechanism is correct gauge (ie P4).
What is going to be interesting here is that if they start with true-scale track for TT-120, then what are manufacturers going to do about the bodies/valvegear that they couldn't make thin/strong enough in 4mm ? They can do it in 3mm ? Hmmm. That provokes some thoughts...
Personally, I think the 'critical date' was some10-15 years earlier. If Lima had made its HO scale models in the 1970's to the same 'standard' that they achieved in the mid-late 1980's when we only had Lima and Hornby wasn't doing much, I think the whole proposition of British HO could be very different today. This would have meant that when the fixed link to HO-land opened, the UK could already have been HO and British products today would be running with compatibility with their European counterparts.
It will be interesting to see what happens in 1:120 TT. They are starting with correct track. One wonders what compromises will be made to accomodate the narrower UK loading gauge. But at least they have the track gauge right! So long as we don't end up with 3mm scale track and 3.25mm scale bodies!!!
Resetting the minimum radius expectation is long overdue. We are either building a model railway or we are building a toy trainset. If you want to build a trainset, then I'm afraid that trainset curves require compromises in the models. If you don't want models compromised, then don't use toy-trainset radius curves!
I always laugh when the 'better OO gauge track brigade' holler on about wanting 'better OO track', then they demand sub-30 inch radius so that they can have their pacific locos running round with massive front and rear overhang!!! Toy trains comes to mind.
  • Love
Reactions: 1
Well, I’ve been overjoyed with this announcement and am happily planning “something“ in 1/120th scale.
IF nothing happens in British outline, I’ll just adopt my plans for modern era German outline but I’d rather go British! Dare I wish for a Hymek?
...Resetting the minimum radius expectation is long overdue....
And regarding this aspect:
There's a 'reset' alright, Peco's 'medium' radius point is 36" substitution radius, (and Peco claim it is close to B6) which is near equivalent to the 60" radius required for large outside cylinder and valve gear steam models to operate reliably in P4. That's on sale now, along with matching flexitrack; with 'small' (unspecified, possibly 24" radius?) points and a diamond crossing listed to come. No 'set track' provision...
This is a very welcome development. Perhaps Peco will be moved to expand this thinking into some of their other track ranges?
I am willing to try peco TT 120 , but at this moment in time there is no British rolling stock to run on it , fair enough there is a class 31 in the offing and may be a class 66 , but I would love some British steam loco`s , my heart is set on the southern around 1950/60 , so what are the chances of a 2 BIL in TT 120 , I wont hold my breath...lol
  • Like
Reactions: 1
To be perfectly honest, I think the TT:120 thing is an attempt at creating a whole new market for people to spend their money on.
Think about it: the OO market is basically saturated. All the major locos and rolling stock are being made and there are few opportunities for commercially viable products left. If a new market is created in a new scale, the whole thing can repeat itself.
Personally, I couldn't be bothered with TT:120 because it is too small. 4mm is about right for most people and for those that it isn't, there is 2mm.
O Gauge is far better - now there's a market which is now proven and has lots of opportunities, although sadly, most layouts I see I made by 'plonkers' - people who buy stuff and 'plonk' it on their layout with none of that ancient art called 'modelling' actually done. Rather reminiscent of the 60's when every layout had Airfix and Superquick buildings.
I am right with you that the intent was to create a new and different market to obtain continued spending from those that enjoy model railway, but have bought 'everything' they want in OO.
The finer track and wheel standard for superior appearance and much reduced scale compromise, requiring a much larger minimum radius curve proportional to the scale than has ever previously been the norm in RTR scales, is what I see as the USP.
The pitch may well be on the lines 'If you have the space for a 36" minimum radius OO layout, in that same space a finescale model railway of superior appearnce may be constructed in TT:120'. Competes with OO on 'fewer compromises', doesn't attempt to invade N gauge 9" radius territory for 'Waterloo in six by four feet'.
Will it fly? Possibly, before the Putin economic torpedo was launched. Now? Not so much...
  • Like
Reactions: 1
While chewing the fat yesterday with a nearby old mucker, (we both got the call for a Covid booster, and decided to celebrate together, since we were able to arrange the location for the jab in a village with an assortment of good pubs) he revealed that the TT-120 plot appeals to him, and he has had an idea. He has a stash of packed away 18mm gauge EM from a long ago C19th layout. That's a track gauge a whole 0.1mm out for Brunel's barmy branchline to Bristle blunder of 7 feet and a quarter inch gauge.
The RTR TT-120 might supply some mechanisms suitable for dual gauge operation, during the inevitable correction to standard gauge (old EM mechanisms he has) and then we can have all sorts of fun of the sort the GWR always denied; traction and trains of vehicles of both gauges, all mixed up. I did float the idea that Z gauge mechs might offer an NG railway sharing the route - triple gauge trains! - but strangely that didn't fly...
1 - 14 of 14 Posts
