QUOTE (Gwent rail @ 24 Jan 2007, 09:42) <{POST_SNAPBACK}>Thanks for the reply Graham, you clarify a number of points with which I would not argue.
As with most things, a little knowledge is often dangerous. I too have seen other layouts where the use of Sundeala has caused a problem. I would say that these have been caused by ignoring one of three guidelines that are necessary to use the material with success.
1) If your layout is subject to frequent atmospheric changes, don't use it, the changes in humidity will cause it to distort.
2) Follow the instructions included with every pack of "Sundeala Hobbyboard" (as supplied by model railway outlets) and condition the surface before use.
3) Prime the surface of the board with a non-waterbased sealer or paint before using plaster or wallpaper paste on it.
In my case, my layout is a permanent one, in a spare bedroom, where the conditions do not vary significantly. I am also careful to prime any scenic areas, rather than building on top of the untreated board, thereby avoiding any possible absorption of water.
If my layout were intended for exhibition, or even to be housed in an outbuilding that is not kept at constant temperature, I would totally agree with your preferred option i.e. 12mm Ply.
As for the magazine mentioned, I does amaze me that they advocate the use of Sundeala without giving proper guidelines on it's use and even claim to use it themselves, without clearly giving preparation details.
If you and I are talking about the same people, they even sell a booklet on building baseboards without mentioning how to properly condition the surface.
Thanks for giving a clear reasoning behind your dislike of Sundeala, I hope that reading our posts will be of help to someone thinking of trying it for the first time.
Thanks Jeff,
I pretty much agree with you on all points.
I personally tend to take a 'belt and braces' approach and choose materials known NOT to have problems - I consider my layout an 'investment' which is going to be with me for at least 10 years and I don't want to knowingly introduce problems, afterall, I don't know where my layout could be moved to or stored at some point in the future.
In fact, 5 years ago, my layout was stored in my parent's garage for about a year, here in Sydney. The temperature ranged from around zero overnight to 45 degrees plus during the day. The layout suffered no damage at all bar a little bit of rail expansion in two places.
In the long run, the use of appropriate materials and measures saves money. Doing it wrong and then having to fix it costs more.
I agree with the sealing approach - in fact I do that on all my cork track bed. In practice, it doesn't need to be done because I've never had cork have a problem, but I do it anyway.
If you seal Sundeala, what happens when you put pins into it ? Doesn't that break the seal ? One club layout I was involved with did this and ended up with a little bit of localised warping when ballast/PVA was added.
The 'magazine' is the one you are thinking of and layouts of said magazine do exhibit level surface problems - I've seen them.
Graham Plowman
Thanks Jeff,
Graham Plowman
