Hi, I have recently just fitted a peco turntable to my DCC layout and it works fine (however I only use 1 line in 1 line out). However you must make sure that when lined up with each track the correct wiring is done; you must check that each rail is of the same side as the turntable, like with DC. Hope this helps.
