QUOTE (Breaston @ 24 Nov 2007, 07:57)
<{POST_SNAPBACK}>Hi,
I am using Hornby Select control units. I know how to use Hornbys version of a point motor having to type in the number then select it etc gets on my nerves to be honest, so I would like to know is there any way I can wire up point motors to work with switches insted? if so, can anybody explain to me how to do this, please, and if possible, the cheapest method as once I get started I will use quite a lot.
Many thanks
***Yes, and its simple to do. Just connect momentary SPST switches to the coils of the point motor.
The simplest way is as follows. an explaination of the motor wiring / switch configuration first.
(1) a twin coil solenoid usually has three wires to connect, left/common/right.
(2) in some cases four terminals If it has 4 terminals - 2 on each coil, wire one form each coil together to make a "common" then it too will have a 3 wire left/common/right connection.
(3) There are TWO terminals on a momentary SPST pushbutton switch
the "common" wire that goes to both coils is wired direct to one side of a power supply (12~18 volts AC or DC)
Each of the other wires is wired to one of the terminals of a momentary push button switch.
The other terminal of the switch is wired to the other side of the power supply
TIP: You mention you want t osave cost. An old laptop computer power supply is excellent for point motors - and can ften be had free as laptops are regualrly superc4eded/replaced/break and their power supply is always still good as new.
A laptop Power supply is usually 3 amps at appx 18 volts - lots of good power for the point motors - OR an entry level DCC system!!
On a laptiop lead, when the plug is removed there will be two wires ...the centre or striped wire is usually positive.
DCCconcepts
