A question - has any MRF member used Peco points without the spring fitted,
in a trailing manner so that the blades move over as required when the train
goes thru the point from frog to toe the same way all the time?
This would then save on a point motor & control method.
To me, Insulfrogs pose no problems but if Electrofrogs are used, then I think
the frog rails will need to be modified so that only about 1" -(25mm) is not
electrically connected.
