QUOTE (keith @ 30 Jul 2006, 21:19)
<{POST_SNAPBACK}>i have recently started to turn my dc layout into dcc (u thought the trains would run better)most of the trains do but nearly all of them struggle of points,can anyone help please
Are you absolutly sure that all the wheels & pickups are OK ?
Does this happen only with specific locos or specific points ?
Double check with a meter, adjust & clean if necessary. Also check that you have good continuity throughout the pointwork rails & that the back to backs are OK. Momentry shorts because of wide flanges, too narrow back to backs can cause problems with DCC which are not noticable on analogue.
If the DCC system shuts down (the overload on DCC is electronic & virtually instant, whereas on analogue there is a delay before the overload operates.)
Hope this helps - if not please let us knowe & also what system, loco's & pointwork you have.
best regards
Brian
