QUOTE (johnukhenry @ 24 Jan 2007, 19:38)
<{POST_SNAPBACK}>Bought a Rail Frieght G/Farish Class 20 for £47 basically to use the chassis for my London/Stratford Class 15 bodies, but cant work out how the hell to get the body off at all. Built solid as a..........
anyone have some ideas ?
Thanks John
You need to remove the nose first using a flat blade between the nose and the body. It is held by a clip at the top which usually breaks (BlueTak is used to reattach the nose). Once the nose is removed a small screw will be revealed which once removed the chassis can then be pulled downwards away from the body.
