1 - 7 of 7 Posts
HI
I AM ABOUT TO RENUMBER AND RENAME SOME HORNBY A3s THEY ARE ALL THE SUPER DETAIL ONES IN BR GREEN.
CAN ETCHED NUMBER PLATES BE LAID OVER THE EXHISTING ONES OR DO THEY NEED TO BE FITTED SEPARATELY ?
ONE CONVERSION WILL BE HUMOURIST AND I HAVE SOME JACKSON EVANS CORRECT SMOKE DEFLECTORS, BUT ANY IDEA WHERE I
MIGHT GET HOLD OF SOME OF THOSE SMALL ONES THAT WERE FITTED ON SOME A2/2s. PERHAPS I WILL HAVE TO MAKE SOME
PS ANY ADVICE ON THE REMOVAL OF EXHISTING TRANSFERS WOULD BE GRATEFULLY RECEIVED
REGARDS
TOM
You should be able to carefully fit the new etched plates over the existing ones. As for the small deflectors I have a spare set in my bits box but it just as easy to cut from brass shim.
Removing numbers. Can be a bit tricky - It depends on the loco but I have used meths carfully rubbed on with a cotton bud. If you are very careful you can use a glass fibre pen. Tee Cut is also good for removing such detail.
Probably teaching my grandmother to suck eggs, but before renumbering check other details like tender types - the A3s had an awful lot of detail difference.
Discussion Starter · #5 ·
QUOTE (Saint Johnstoun @ 16 Jul 2008, 22:19) <{POST_SNAPBACK}>You should be able to carefully fit the new etched plates over the existing ones. As for the small deflectors I have a spare set in my bits box but it just as easy to cut from brass shim.
thanks very much for your advice and if you want to sell your small smoke deflectors i would be most happy to buy them .let me know
kind regards
tom
Discussion Starter · #6 ·
QUOTE (butler-henderson @ 17 Jul 2008, 18:20) <{POST_SNAPBACK}>Rubbing a toothpick on the numbers was all that was neccessary on a Hornby BR Rebuilt Merchant Navy to remove the required digits.
Thanks for your advice.Can i ask what varnish you used to seal the new transfers . On super detail hornby locos ,is it mat or satin.
REGARDS
TOM
Discussion Starter · #7 ·
QUOTE (BRITHO @ 17 Jul 2008, 16:01) <{POST_SNAPBACK}>Probably teaching my grandmother to suck eggs, but before renumbering check other details like tender types - the A3s had an awful lot of detail difference.
hi
thanks for your advice your dead right its like a minefield
tom
1 - 7 of 7 Posts
