Rob's Painting and lining efforts
17646 Views 58 Replies 13 Participants Last post by  Rob Pulham
Along side lining the A3 I have also taken the plunge and lined Severn - my first 7mm scale loco build. I scratch built it in 2010 and painted it blue but I decided to give it the finish that it really deserves - although I doubt that Colonel Stephens would have splashed out on lining the wheels.....
I have gone a bit mad with the photos because I am really pleased with my efforts on this one.
All the lining has been done with bow pen and compasses using Humbrol enamels.
I made a couple of jigs to assist with the lining and I will take some photos of them tomorrow.
41 - 59 of 59 Posts
The final item that I completed in the last week is the Gladiator Beer van.
A recent discovery in the Vallejo Model Colour range was Dark Sea Grey and Leather Brown, which work very well as an acrylic substitute for the Tarmac and Matt Leather that seem to be favoured by many as weathering staples.
Although I haven't managed any modelling while in Wakefield for what seems to be far too long I did manage a bit more painting and weathering over the weekend. Apart from couplings the NBR Dropside wagon is finished.
It's not clearly visible anymore but I have added a paint date of '19 in the crescent on the sides and weathered it based on photos of NBR 3 and 4 plank wagons in Tatlow.
Lastly I added it's load after playing around painting that with some 'wood' coloured paint....
QUOTE (Makemineadouble @ 13 Jul 2015, 23:23) <{POST_SNAPBACK}>inspirational Rob those wagon a class job.
Thanks MMaD.
Hopefully this will be in the same vein - While I had the paints out I also finished the weathering on the NBR Floor Cloth wagon that I built from a Majestic Models Kit (Now with Chris Basten at Dragon Models).
The 'floor cloth' rolls are made from coloured light card (file dividers). I just need to add a tarpaulin sheet now to finish it off.
Over the last few weekends in odd moments in between gardening I have put together and painted another Slaters Salt van.
In contrast to the one I built earlier which was depicted as faded and worn I wanted this one to be in a recently out shopped version of the livery so I started by giving the wagon a good coat of paint (as opposed to the deliberately patch finish on the first one).
Next I pondered on how to get over the fact that the transfers which are homemade and printed on clear decal paper have a tendency for the colour to wash out of the yellow when applied over a green base coat.
While it worked brilliantly for the faded livery it doesn't for a newly painted livery so I thought that I would have a go at over painting the yellow bit of the lettering by hand.
I used Vallejo Sunshine yellow but found that it took a few coats to get it to cover on the slippery surface of the transfers. In all it took six sessions over two weekends to do both sides it's far from perfect but I am happy with the results and I will use the technique again.
Finally a shot of them both together.
Yellow is always a problem. I think you've cracked it magnificently!
I will also have a look for your approach to doing the other salt wagon. that looks very good. Your work on the vans has suggested new weathering techniques to me too.
Hi Iarnrod,
Thanks, you are right about the yellow it probably wouldn't have blended in as much on a different base colour.
This might help you in terms of seeing the 'patchy' basecoat that I did on the original wagon.
After that it was just down the the translucent nature of the transfers and some weathering.
Thank you, Rob, that is most useful. I am an aficionado of salt or hairspray weathering depending on the effect I am after, but it's always useful to have another arrow in the quiver!
very nice job ,it would be crime to weather the
fine work you have
The latest item to pass across the work bench is a Connoisseur Models, Brass/Whitemetal kit of a former GER Sand wagon. I have finished this as a BR example because it's destined for the small adds to raise funds for Telford. I do enjoy building Jim's kits and this is no exception giving about 23 hours of
pleasure to get it to this.
I couldn't resist picking out the eylets in weathered brass.
For the last couple of weeks modelling has taken a back seat to gardening, and no that doesn't mean anything further has been done on the Rhubarb Triangle. It's been gardening up North.
I did manage a bit of time at the bench though and those of you who look in the small adds may remember me advertising a couple of 3 Aitch wagon kits that I had bought from the Guild E&T lists?
There wasn't any interest in them as they were so I decided to build the second one and add some detail and decay to them to portray them as condemned wagons ready for breaking up.
The first one was the 5 plank version that I had already assembled. I added a false floor (made from some styrene planked sheet that came with my Dragon models Caledonian single Bolster kit - I must ask Chris Basten for the source of it because it's actually quite good stuff). Over that I added inner sides that were scribed and washer plates etc. added to. Finally after painting I found various bits and bobs of scrap junk to add a bit of interest inside.
Unfortunately we have had storms here today which have resulted in odd lighting that has enhanced the reds in the rust which are much more subtle in reality. - Apologies too for the photo overload, I was struggling with the light and liked them all.
Because I hadn't assembled the second wagon I had a bit more scope with what I could do with it and Chris suggested an opening door. Out with the Olfa cutter to add the planking detail inside and to remove one of the doors. A bit more hacking and assembly gave me this.
41 - 59 of 59 Posts
