1 - 20 of 31 Posts
No Longer Active.
Roco have announced a wireless MultiMAUS.
The advance information we have from Roco is in German so the details are a bit sketchy. It looks like a complete starter system comprising the base unit/amplifier, Rocomotion software & the first handset (which looks like the wired Multimaus, except that it's blue) has a RRP of 399.00 euro, with extra handsets for 199.00 euro.
It look very much like a radio system & not IR.
I'll post more details when I get the English version catalogue (probably in a few days).
UPDATE: Info and links to product, a couple of posts down.
DT
This looks great. It uses wireless which in my opinion is better than IR.
The basic framework of IEEE 802.15.4 wireless conceives a 10-meter communications area with a transfer rate of up to 250 kbit/s.
It works in the following frequencies:
868 MHz to 868.8 MHz range (in Europe) - 3 channels
902 MHz to 928 MHz (in North America) - up to 30 channels
2400 MHz to 2483.5 MHz (Worldwide) - 16 channels - which is the same as 2.4-GHz 802.11 Wi-Fi unfortunatly
I'll be trying to get one of these as soon as it comes out. It encompasses the quality, usefulness and simplicity of Roco MultiMaus.
Premium Member
QUOTE (Doug @ 14 Jan 2008, 09:07) <{POST_SNAPBACK}>The first link is English, but it came up in German the first time I saw it. You may have to go to their homepage, then select English to set an 'English' cookie, then check the link again.
Yes I tried that going via the products menu and it was still in German. I have now tried again going through the bit on the lower right and it has come up in English. But I cannot locate the new system on this listing.
Premium Member
QUOTE (neil_s_wood @ 13 Jan 2008, 22:20) <{POST_SNAPBACK}>Yes I tried that going via the products menu and it was still in German. I have now tried again going through the bit on the lower right and it has come up in English. But I cannot locate the new system on this listing.
This happened me too, I got round it by cutting the item number from the german page, then going to the english home page and pasting it into the search box and voila!
Rob
DT
For those that can't see the English:
multiMAUSPRO
preproduction sample image
multiMAUSPRO "the new standard in model railway controls"
Since its market launch a few years ago, multiMAUS has become a standard for digitally-controlled model railways. Its ease of use, attractive price and, last but not least, its ergonomic shape have already won the hearts of many model railway fans.
Now Roco is setting a new standard with multiMAUSPRO. This unique combination of cutting-edge wireless communications and the newlydeveloped multiZENTRALEPRO control unit shows how seriously Roco's development team takes its customers needs. Simply follow your train without losing control of the rest of your layout or of the other trains running on it. Use the new route controls to define routes more or less as you travel by. Drive a model double-heading train, just like the real thing, while looking at it directly and without having to remain seated at the central controls.
The handy multiMAUS format has been retained, together with the simple, intuitive user interface and the attractive price. And you know that you will be able to use it for many years to come thanks to its update compatibilities.
* Controls for up to 9999 locomotives, 1024 turn-outs and solenoid-operated articles
* Wireless in accordance with digital communications standard IEEE 802.15.4
* Extensive effective radius. The digital communications standard ensures a good connection to your multiZENTRALEPRO at all times
* Single-handed operation, for both right-handed and left-handed people
* Double-heading. Simultaneous control of two locomotives pulling the same train
* Routing control. Miniature layout mimic diagram in your multiMAUSPRO
* Ergonomic for both young and old
* Clearly legible display
* Brightness control for display background illumination
* Off-the-shelf batteries or accumulators (3xAAA))
* Long battery life thanks to energy-saving mode
* Low-battery warning
Price: 199,00 Euros
I do wonder what havoc will occur when multiple layouts at exhibitions are trying to use similar (or identical) wireless radio based DCC systems!
This is not specific to Roco, but once the channels are all used up it could be quite amusing.
Do we know whether these systems choose their channels randomly, or will someone have to control it at such an event as is done for standard R/C equipment?
Just another modeller
QUOTE (Gordon H @ 14 Jan 2008, 21:58) <{POST_SNAPBACK}>I do wonder what havoc will occur when multiple layouts at exhibitions are trying to use similar (or identical) wireless radio based DCC systems!
***Its a good question Gordon - there have certainly been conflicts at larger US events where layouts with lots of radio handsets were adjacent to each other.... system by system it is handled a bit differently I think.
Worthy of a bit of questioning on one of the US or EU based forums I think...
DCCconcepts
DT
It is going to end up like Radio Control (RC). When you fly your plane at the park there is not much chance of trouble, but when you go down to the club airstrip, you have to register your frequencies.
A frequencies table is put up and if there are say 10 frequencies available, there are 10 slots that can be used by members. If someone comes in with a radio set to wont of the allocated frequencies, he does so with the risk of being kicked out of the club and paying for any damage he causes.
The trouble with wireless DCC is that it is in it's infancy and there are no standards. Every manufacturer uses their own system and even the ones using wireless radio use different technologies in the licence-free spectrum. So some systems may pick up interference from garage door openers whilst others will get interference from home Wi-Fi networks.
At the latest CES 2008 technology show in Las Vegas that had a few thousand TVs on show amongst other new products. There were a few pranksters using TV-B-Gone clickers that turned off the sets from a distance (link). They cycle through IR signals of different manufacturers until the TV switches off. Imagine if the same thing happened at a show like Warley with the trains - it would be chaos.
Chief mouser
And just when I was getting the hang of my Multimaus!
Premium Member
QUOTE (Gordon H @ 14 Jan 2008, 23:58) <{POST_SNAPBACK}>I do wonder what havoc will occur when multiple layouts at exhibitions are trying to use similar (or identical) wireless radio based DCC systems!
You could have such a laugh with that if you took your own radio controller down to a exhibition.
I don't think there'd be a problem with multiple users in one hall. I imagine that like with the similar ESU remote controller, or with DECT cordless phones, each handset has to be 'logged in' to it's base station. It's all very... digital.
DT
Very true Dogmatix. Even if two controllers are using the same channel, they should work in the same area. The reception quality may be reduced due to interference, but as the information is not continuous, it shouldn't be a problem. It is always better to use clean unused channels if other users are present.
I've just remembered that RC is now starting to use bi-directional 2.4 GHz technologies to get away from the separate channel problems. The transmitters and receivers constantly talk to each other making sure the signal quality is the best available. If interference is detected, they automatically switch channels.
If problems do occur in an exhibition, then there is a very simple solution. Plug in a tethered handset(s) and use that/those instead.
All these systems have this capability; something that R/C model aicraft and cars don't have
Basic Dynamis is probably the only system where you can't do this, but adding the Pro Box allows tethered handsets to be used.
With IR there shouldn't be as much of a problem with the limited range available.
Hello everyone,
This is my first post here. I came across this thread while checking out the Multimaus and the untethered Multimaus Pro looks very tempting. I currently have a Lenz Set 100 with two red Lokmaus II handsets so I know the Roco and Lenz are both XpressNet but my question is how does the Multimaus Pro actually connect to a Lenz system as it looks like the handset receiver is also a powerstation?
Barry
http://www.britanniacreek.net/
1 - 20 of 31 Posts
