QUOTE (jag @ 17 Feb 2008, 17:36)
<{POST_SNAPBACK}>I recently bought a very nice Roco DSG Sleeping Car (I think 2259) but it has a non-standard coupler at both ends, well it's non-standard in terms of my limited knowledge. Is it possible to change them to standard ones?
I would attach a photograph but haven't worked out how to do it yet!
Hello Jeremy,
To attach a photograph first upload it a free image hosting website or your own internet space if you have it, and then to post on the forum copy and paste the full address of the image i.e."http://www.blahblah.com/images/image1.jpg" into your post and between {img} and {/img} except use square brackets instead! e.g.
{img}http://www.blahblah.com/images/image1.jpg{/img} except use [ and ]
Image:
http://www.modellbahn-spur-n.de/
Regarding your unidentified couplings - they are either Fleischmann Profi couplings (still in production) or Roco couplings (not produced any more). If your coach is 2259 then it is an early model (1978 - 1984) and won't have NEM sockets which means they'll be slightly more difficult to change - prize the cover off the coupling box, don't loose the very small spring inside and replace with a coupling with the same end. You could of course take the coupling off one end and put it on the end on another coach and keep the pair of coaches coupled - thus you don't need to buy any more couplings!
Hope this helps, but a picture would clear things up! Fleischmann ones are bulkier than Roco I recall.
