QUOTE (neil_s_wood @ 5 Jan 2009, 04:42)
<{POST_SNAPBACK}>I find it interesting what has been said about cork as years ago when starting my first layout I went into Hearnms Hobbies to buy loads of foam underlay and was advised by an experienced modeller who works there that foam wasn't really suitable for the Australian environment as it degraded quickly. I used cork ever since.
I have found a cheap source here in Melbourne. Clark rubber used to sell it for $5 a square metre, or at least they did when I laid my track a year or so ago.
***Peco foam was / is indeed unsuitable, but its a totally different animal. This is what I mean by habits being perpetuated - all synthetics were lumped into the same bin because of one modellers habits or because one brand was inadequate.
We aren't talking classic low cost sponge type "foam rubber sheet" as per Peco but closed cell foam - it has a very slightly textured top and bottom surface but that surface is literally "closed" meaning it will not absorb liquid.
Its cut edge has a very fine cellular structure but each "bubble" is also "closed", meaning that its firm-ish so good as a trackbed but remains very resilient due to the springing of each "bubble". It really is fabulously easy and nice to lay and work with compared to foam.
If you buy the higher quality stuff (as I use in our own trackbed) it has a 10 year UV rating - its actually used to make swimming pool covers so that will give you a good idea of its "weather durability". I would be willing to bet it'd outlast cork in many places.
If you want to do some looking at characteristics, look for info on "EVA Foams" (The Military use them a lot for things like cold weather sleeping mats, insulation on all weather systems etc - they are really tought)
** TIM - an equivalent 2400 x1200 x5mm thick sheet of high quality closed cell foam sells here for approximately $AUD 40~$45 or GBP. Thats about GBP20 for 2.8 square metres.
Pre-cut trackbed with 60 degree shoulders is appx $A60 for 100 linear feet - still not a bad price as its accurately cut, curves naturally/easily to about 30" radius and is also part split underneath in case you want to make tighter curves easier to make and is very efficient - wastage is nearly zero, re-usability is dead easy too, as soak it in detergent and water and any old glue and ballast will come away easily, eaving the original stuff ready to use again.
Tim - If you want to try it send me your street address via EMail to the work address and I'll send you several lengths to experiment with...
