QUOTE (Doug @ 28 Aug 2008, 20:36)
<{POST_SNAPBACK}>Just to be super clear - in true forum fashion where you get multiple similar answers to a simple question...
Just add 1 to the existing CV 29 value. Read it first and then do the maths. The existing value will be different depending on manufacturer default setting.
***Spot on Doug.
Most common default is 6 in CV29.
BUT..... You cannot read the CV to check it with a dynamis
So if you have a short address for that loco, set it to 7. If you have a long address, set it to 39
if you muck it up, don't worry, just do a reset (cv 8 to 8 if lenz, Cv30 to 2 if TCS) then address will be 3 and CV29 will be at default.
The direction fix should be your next step, set CV29 to 7, then change the address however U want.
all fixed
