1 - 5 of 5 Posts
In the past I've used a fast clock:
a simple search found this: fast clock
mine simply plugged into to loco net Being a digitrax user. I've operated huge layouts to a timetable with up to 12 operators and it can be excellent fun, the the timetable needs to be achievable. Fast clock can create operator stress particularly when operating with a new and untried time table. A good friend of mine
came up with an alternative, which was to use a broken clock, and simply advance the clock by 1/2 hour intervals once all operations from the previous period were complete.
· In depth idiot
Running a timetabled service is the reason I have a layout, and most of the models, and why DCC was such a natural choice.
Same as Alastair though, I would suggest a sequenced timetable, with the rate determined by the operator rather than a clock. The simple fact is that if attempting to perform what were fairly brisk operations on the real thing (e.g. reversing a steam suburban service including relocating the stock from arrival on down slow, across the ECML fasts, to the up slow platform or bay) you cannot use a speeded clock, it is a real time operation. You might 'pinch' 20 or 30% of the time the prototype required, because you don't have to wait for the section to clear, and can run much closer headways, but that's about it if observing realistic speeds for the movements.
So then you just sequence the other movements that are run throughs or stops but without any shunting in turn, and as Alastair says you can pick it up and leave it without any further to do.
1 - 5 of 5 Posts
