Picked this up last night. Needed a replacement buffer. It is now in the running fleet and I am waiting for the hot boxes to develop.
It romps away with six or eight of my mixed suburban rakes no bother. The prototype was flawed in that Mr T used the same axleboxes as the V3 tanks where 3 cylinders gave less stresses but with two they didn't stand it. It is said that ET didn't tell the board that they were going to be 2 cylinder but in the end it didn't matter as it was down to British Railways to duplicate them. When I was on Waverley in the 1970s (purser) a retired Helensburgh driver used to come for a sail regularly and he swore by the V1s and V3s. They had the NBL built L1s for running in at Eastfield but like anything Thompson they were treated with contempt - B1s apart. Spent his last years driving 303 EMUs and said that there was no interest in the job by then.Wonderful isn't it, that such a troubled design has such a fine model.
One of the rare exceptions to the engineering mantra 'if it looks right it is right'. Deployed on the KX suburban services they were commonly referred to as 'Concrete mixers' because of the dreadful noises so often heard while running; and the all too frequent 'not running' because the cause(s) of one or more of the noises had resulted in sufficient damage.to disable the loco.
But the Hornby model will work splendidly on any layout. A slight lack of imagination in the mechanism design apart - the decoder socket is in the right place in the bunker, good work there; but then no direct access by lifting out the moulded coal load which could have made possible a decoder installation with no need to remove the body, which would have been a first in OO - it's all good. The wiper pick ups on the bogie may need adustment to prevent skidding wheels is all. There's enough weight for traction on both the typical suburban service set, and the maximum freight load they were safe to operate. It's easy to add weight if you are going to use yours to drag 16 sleepers out of KX up the 1 in 105...
He wasn't a competent engineering designer, and considering that the design team were 'experienced safe old hands' it has to be down to the concepts he insisted on. The 'assemblage' locos, B1, K1, O1, using stock parts of proven design worked well enough, but all the locos with novel design features a failure, mainly because the frames and mechanism components specified weren't up to the job.... like anything Thompson they were treated with contempt - B1s apart...
I'm pretty certain that there was an article in the Railway Modeller in the late 1960s about doing such a conversion, but I wouldn't have a clue which issue it was in. It's a conversion (together with Peter Drummond's projected HR example) that I have often considered doing, in spite of having two unmade DJH kits that I never seem to get around to doing anything with.Elsewhere, there are those who are contemplating the conversion of an M7 into a Caledonian Railway 439 class.
I have four DJH 439 Class locos dating from the 1980s - all well worn out - the mechanism was not the most durable.I'm pretty certain that there was an article in the Railway Modeller in the late 1960s about doing such a conversion, but I wouldn't have a clue which issue it was in. It's a conversion (together with Peter Drummond's projected HR example) that I have often considered doing, in spite of having two unmade DJH kits that I never seem to get around to doing anything with.
The basic job of the conversion should be relatively straightforward, with probably the hardest part being adjusting the width of the cab and bunker.
The GNSR had some 0-4-4Ts as well, but a better starting point for one of them would probably the recent Midland Railway 0-4-4T by Bachmann.
My four - still around but need some TLC.I'm pretty certain that there was an article in the Railway Modeller in the late 1960s about doing such a conversion, but I wouldn't have a clue which issue it was in. It's a conversion (together with Peter Drummond's projected HR example) that I have often considered doing, in spite of having two unmade DJH kits that I never seem to get around to doing anything with.
Very pleased with my three, all run smoothly, look well and are dimensionally accurate. Only fault is the coupler mounting, putting the couplers way too far outboard, but anyone handy can improve this.What are folks' take on the Oxford Rail N7?
Body arrived today - some cosmetic work plus renaming and renumbering to follow.Sorting out the spares department and managed to get enough in the way of parts to build up a spare Gresley A3 (without loco body) which has now been run and tested - however a body has been sourced so I wonder which loco it will become. I would like St. Simon with the small deflectors but don't have a spare GN tender. This chassis is a very quiet runner too
I'm thinking of Captain Cuttle?Body arrived today - some cosmetic work plus renaming and renumbering to follow. View attachment 21740
