I first need to stress that this is only an idea. It is not something that I've tried.
If you are using peco track and pointwork then their points have a 12 degree angle at the separation. They make a short crossing with a 24 degree angle which is correct for a scissors crossing but only if the two tracks are fairly wide apart. It may be possible to cut the ends of the points and the crossing to get them to fit together at much closer than the original distance between the tracks.
Good luck with the project. cheers, Robert.
