Hi Erkut
Thanks a lot!
All parts made by myself. (except wheels, buffer )
Im useing different thickness of ABS sheets. The base is 3mm but quiet often im useing 1mm of that. 1mm is better on curved surfaces (more flexible). I cut (with CNC mill) and build a frame and after i put/bent the 1mm ABS sheet to the build up frame. Of course always need to sanding and filing at the joints.
The glue type is PIKO Fix (not a special one)
If you have more questions please dont hesitate
Ákos
Thanks a lot!
Ákos
