I am trying to control all points with the Seep PM1 primarily due to the fact that they are inexpensive and that they have an inbuilt switch with which I can control the point frog polarity. Having researched this topic I have found a suitable method for the wiring as indicated on: http://brian-lambert.co.uk/Electrical.htm. However, I also wish to represent and control the point operation from a control panel that displays the point direction via LEDs as selected by a switch.
I wondered if I replaced the SPDT switch as per Brians diagram with a DPDT switch and used the second half of the DPDT switch to select an LED routing, would this work? I have made an attempt at a circuit but don't seem to be able to post it on here, if you PM me I can email the diagram to you for comments.
Many thanks in advance
Whistler
Whistler
