QUOTE (John Webb @ 23 Dec 2008, 01:39)
<{POST_SNAPBACK}>Neil, I assume that the bridge to the right of the terminus conceals connections to another part of the layout.
In which case if you are using Colour light signals a two or three aspect on each platform as starter signals and a GPL (Ground Position Light) signal on the siding (add a trap point to the siding?)
If you wish to model the radio-token signalling there would be some extra signs as well.
Are the crossovers on the main line (I know little abut the Highland main line) converting a standard two way stretch into two single bi-directional lines, acting as emergency crossovers or what?
Hi John,
You are right that the bridge does conceal connections to another part of the layout.
The crossovers are emergency crossovers.
Neil
