This is a well recognised problem from the time this model was introduced. Unless the previous owner has done any work on it, the leading bogie is oversprung and lifts the front end, the leading coupled wheel is softly sprung, the loco isn't that heavy so the driving wheels slip all the time, and it's really only the rear coupled wheels that are providing traction. And then the final problem, it is geared 40:1 with a 'fat' worm which makes the drive draggier than it needs to be, and the higher than usual gearing malkes it great for slow speed control, but limits maximum speed.
What to do.
Take body off, remove front bogie, cut about one sixth off the bogie spring, and just use that small piece slightly stretched to lightly spring the bogie. (Keep the rest of the spring, it's good in pieces for other locos which have no bogie spring fitted!) Now the leading coupled wheel, take the sprung saddle out and either stretch the spring to near double the length, or find and fit a stiffer spring. On the chassis remove the plastic doodad for a decoder, and if you feel so inclined remove the decoder socket and the cast attachment points it sits on, hardwire a decoder which can go into the smokebox, and use the resulting void over the coupled wheels to pack in lead for weight to improve adhesion.. (A faster motor, the Mashima 1426 can be substituted - if you can now find one - there are doubless alternatives but I cannot identify one. You do need a good worm puller as Bachmann worms are on TIGHT!; I broke my old worm puller the first time out on another Bachmann loco... There is though another simpler way if using DCC)
You are now into the hell of putting the body back on, holding the various detail parts under the body void apart, as you slide it onto the mechanism; and the dire process of adjusting the speedo cable so the loco doesn't run like a three legged dog. (Bachmann dropped this speedo cable detail after this model and the BR Std4 2-6-4T, due to customer feedback on the difficulties it caused; as it was essential to disconnect and reconnect if taking the body of for maintenance, or decoder fitting.)
This mechanical adjustment will enable the loco to both pull much better and achieve scale for 70-75 mph. Still not fast enough for me, so I used the DCC feature of increasing track voltage, so that there is 15V at the motor terminals, and that has it capable of scale for 95mph. Consult your DCC system manual to see if this feature is available. This does the job on this loco and several other 'slugs' that I own, and I have operated this way for well over ten years now with not a hint of trouble.
For extra traction, mine also has lead sheet on the cab floor and curved to fit under the cab roof, which is not visible in operation with the tender coupled on. (I needed a little more traction to ensure a reliable restart with a full class 5 trainload standing on the 1 in 80 gradient of my layout.)
What to do.
