QUOTE (Makemineadouble @ 20 Nov 2007, 08:31) <{POST_SNAPBACK}>Perhaps you'd like to explain further
As I've never heard of this
IMHO it simply cannot work, but as always I stand to be corrected.
What is practical is to fit a suitable resistor to reduce voltage should the heat/smoke/smoke cycle be short. Seuthe are a bit coy with their literature on the subject. In practice it's a fine line between getting them to smoke, and achieving reason time between fills. The best thing about DCC is you can turn them off and on for maximum effect, this lengthens the cycle, reduces any heat, and is realistic. In six or seven years of fitting these units the only problems I've experienced is one total failure, and one chipped chimney caused by heat.
***Accessory functions can indeed be powered by either the appropriate function wire and a connection to red or black. This is very common on EU made loco's, especially N scale where bulbs are almost always using chassis ground for one side.
basically inside every decoder, as the power enters the decoder all except one via PCB track (the dcc signal) passes through a bridge rectifier, and using a chassis earth does therefore indeed give a half wave rectification.
My area of doubt is not that it will work (it will), but that there will be adequate power for enough smoke - as it is smoke never looks very realistic to me when normal, never mind reduced!! - always too oily and heavy and never nough "energy" in it expulsion from the loco.
BTW - I have a friend that uses Johnsons Baby oil in his units to good effect - however I also note that Stage smoke uses Glycol - I wonder if this might be worth trying?
DCCconcepts
DCCconcepts
