Sound in a Bachmann 9F
4767 Views 18 Replies 8 Participants Last post by  neil_s_wood
Guys I've fitted a Soundtraxx Tsunami sound decoder to a Bachmann 9F and I've done some pictures of the install. I used a Soundtraxx light logger decoder because it was the only one i could get at the time. When time permits I'm going to replace it with a light steam decoder as the whistles may be more appropriate.
The loco, keen observers will notice the extra wires under the cab. These will be tidied up at a later date
Top the tender with the supplied coal load. This will have some real coal added.
The Soundtraxx decoder. Notches were cut in either end of the coal space to fit the decoder into the space.
Bottom of the tender with holes drilled in it for the speaker. I may open up these holes into one large hole as you can get interference from the sound waves reflecting off the holes.
Inside the tender I've fitted a 1inch Soundtraxx oval speaker. This is mounted on an insertion strip, a piece of 1/64th thick rubber, and sealed with blu tack. You can see where the decoder projects into the water space. The capacitor is mounted in a convienent spot with some blu tack.
I'm going to fit a chuff cam as getting the steam chuff in synch is a pain using the auto chuff feature. This will either be a Grizzly Mountain Engineering cam, requires milling of the chassis to fit, or a flat disc cam glued to the back of one of the wheels. I'll proably take the easy option as I'm getting lazy in my old age.
Ozzie 21
1 - 19 of 19 Posts
Nearly run out of space on that one. I forgot to add that I removed the Bachmann weight and mounting pins as it's impossible to get that size speaker in with the weight in place. I'll add weight to the tender at a later date but so far it's not showed any inclination to bounce off the tracks. The other job will be to close up the space between tender and loco. Hopefully all I'll have to do is drill another hole in the drawbar but if need be I'll make another. And last but not least tender pickups. These are nearly complete not that the loco really needs them but I've fitted them to nearly every other loco I've owned and it's become a habit.
Ozzie21
Thanks heaps for that Ozzie.
That is one of the most helpful guides I have seen yet for sound instalation.
Yes, thanks for that.
So, what does it sound like? Is this a 9F sound or a generic steam sound? Any chance of a video?
It sounds reasonable. The steam chuff sound is based on a D&RGW K 26 2-8-2 as is the whistle but the whistle is way off for a space ship. This is why I'm after a light steam version as it has a couple of whistle that may be more suited. As for a video? aw come Doug I've only just got posting pictures sorted out
Ozzie21
O
QUOTE (Doug @ 13 Nov 2006, 18:32) <{POST_SNAPBACK}>Yes, thanks for that.
On another forum, I read that the BR52 (German 2-10-0) sounds are a fairly good match for this loco. I have not tried this myself and have no idea if the whistle is correct, but it sounds good to me (groan).
Of course, I have no idea how easy it is to get hold of the BR52 sounds and load them into the Soundtraxx decoder, so I am just passing this along as a possible idea.
John Russell
Vienna, Austria
QUOTE (John @ 14 Nov 2006, 03:18) <{POST_SNAPBACK}>On another forum, I read that the BR52 (German 2-10-0) sounds are a fairly good match for this loco. I have not tried this myself and have no idea if the whistle is correct, but it sounds good to me (groan).
John Russell
Vienna, Austria
ESU have a bank of downloadable sounds on their website. Unfortunately BR52 is not one of them. Maybe another might do though.
I don't think the Soundtraxx decoders can have new sounds uploaded by users. It is the ESU LokSound decoders which have that capability.
QUOTE (Mark Thornton @ 14 Nov 2006, 09:07) <{POST_SNAPBACK}>I don't think the Soundtraxx decoders can have new sounds uploaded by users. It is the ESU LokSound decoders which have that capability.
Possibly not but the Digitrax and Loksound ones do, so it may be worth thinking about using them instead.
I looked too. There was a BR50 but I don't suppose that's a two cylinder 2-10-0.
QUOTE (dwb @ 14 Nov 2006, 09:27) <{POST_SNAPBACK}>>Unfortunately BR52 is not one of them.
Maybe, it looks like this
QUOTE (John @ 13 Nov 2006, 16:18) <{POST_SNAPBACK}>On another forum, I read that the BR52 (German 2-10-0) sounds are a fairly good match for this loco. I have not tried this myself and have no idea if the whistle is correct, but it sounds good to me (groan).
John Russell
Vienna, Austria
Many German steam loco's had a very shrill whistle - typical German & functional.
best regards
Brian
I have remembered where I saw the BR52 (German 2-10-0) mentioned. The Zimo decoder (MX690 - for large scale models) comes pre-loaded with sample sounds for 5 steam locos (including the BR50 and BR52). Zimo are bringing out a diesel sound collection soon and next year we will see the MX640 for HO/OO scale models (which is the one I am waiting for). The current steam collection can be downloaded from their website and (after unzipping), you can play the wav files in on your PC :-
Zimo Sounds Decoder Project File (zipped)
If you know what you are doing, you should be able to extract the BR50 or BR52 sounds and transfer them to the sound decoder of your choice. Of course this won't work with Soundtraxx. This ability to upload your own sound collection seems to be a common feature of most sound decoders these days (Zimo, ESU, CT Elektronik, Dietz, etc.). Only Soundtraxx are restrictive and don't offer this as an option and in fact threaten you with all sorts of legal action (on the website) if you copy their sounds. Most of the others manufacturers are taking the approach that they will provide and sell the platform (hardware and software), and let others provide the sounds. Retailers can make money out of providing the service to upload the sounds for buyers (since many will not want to buy the extra hardware and software, and learn how to use them). This seems a better business model to me. But I am biased as I want to have full control of what is loaded and understand how it all works, not everyone wants this and may be happy with the Soundtraxx pre-packaged approach. If they had decent British steam sounds I would not mind, but they don't.
Coming back to the original topic of this thread, I still don't know if a German BR50 or BR52 2-10-0 sounds anything like a British 9F 2-10-0, especially the whistle, but you can try it out using the Zimo files above or those on the ESU site. The German/Austrian markets are much larger than the UK market, therefore the sounds for German/Austrian steam locos are easier to find than the British ones right now. There are some good British diesel sounds available from SWD or Howes, but few British steam sounds around, I would like to see that change, before I lay out a lot of money on sound decoders and invest the extra time in fitting speakers in the tenders.
QUOTE Coming back to the original topic of this thread, I still don't know if a German BR50 or BR52 2-10-0 sounds anything like a British 9F 2-10-0, especially the whistle,
To be honest no-one under the age of 50 could possibly have any idea what the authentic sound was. I personally would accept it as close enough. It depends on how accurate you want to be.
Well I chose the Soundtraxx decoder because it's easier to get than the Loksound and cheaper too. We pay A$175 for a loksound decoder and A$200 for the programmer. I paid A$140 for the Tsunami. The range of Tsunami decoders is good too and I have found the sound quality much better than with a Loksound 3.5 decoder. The other side of the coin is how well can I program a Loksound or Tsunami. I spent about 8 hrs trying to get a Loksound decoder to chuff correctly in a Precision Craft Y6B 2-8-8-2 to no avail. It went back to the factory and has disappeared. On the other hand programming a Tsunami is no picnic either with almost 245 Cv's to play with but you can get motor control almost as precise as Loksound and I said earlier they sound better than the Loksound decoders. The decoder I have fitted to the 9F has a nice beefy chuff and this is backed up by using the biggest speaker I can get into the space available. I'm going to change it, the light Logger decoder, for a light steam decoder which from the sound samples has a whistle more suitable to a 9F. A light steam loco in the states could be anything from an 0-6-0 to a light mountain 4-8-2 , a decapod 2-10-0 or even a Santa Fe type 2-10-2.
Ozzie21
"To be honest no-one under the age of 50 could possibly have any idea what the authentic sound was."
Sorry Neil, going to have to disagree on this one......don't forget there are quite a few preserved Standard 9s kicking around the countryside, and both 92220 and 92203 were worked mainine in the late seventies.
QUOTE (BRITHO @ 15 Nov 2006, 23:56) <{POST_SNAPBACK}>"To be honest no-one under the age of 50 could possibly have any idea what the authentic sound was."
So do you are reckon that you have such a good memory of the sound of that specific loco that you could distinguish it from all others and you are under 50? If so put it there mate.
There can't be many of you around. Fortunately the odds that the two or three other people who can distinguish 9f loco sounds from all other train sounds will come past my layout and catch me out is so remote that I am prepared to take the chance.
The point I was making was if you live in the UK, it is still possible to hear a 9F for real. Incidentally I am under 50, but not much, unfortunately I grew up in Southern Electric territory, a steam desert since 1961!
The point I was making is that there are very few people with sufficient familiarity who could tell the sound of different steam locos apart to that degree.
Where in the UK can you hear a 9F for real? Next time I'm home I wouldn't mind checking this out.
1 - 19 of 19 Posts
