Need some pointers on this as I'm now at a total loss.
I've just put a TCS-M1 decoder into my Hornby Castle Class Loco.
I just ignored the DCC socket as I didn't think this loco had one.
I also removed all chokes and capacitors.
I'm using a Bachmann EZ command control unit, the two loco's that came in the starter set work fine.
The Loco I've just converted will run fine on 90% of the track but in 1 area it goes mad.
As it enters the area it speeds up slightly at that point I have no control of the loco at all.
I turn the power off to the track, and when I switch it back on again I can't get the loco to respond at all.
I only need to move the loco to the next bit of track and full control is restored.
I've rewired that section of track and replaced the track. still no joy.
To get it to work I took another bus cable direct from the controller to feed this part of the track, everything working fine. If I connect all the track feeder cables to the bus cable using the white plastic conector block the same fault happens.
I've now got 3 bus cables all joined to the controller cable spreading out round the layout with the track feeder cables joined to these.
I'm now lost, ok it's working but I think it may be hiding another fault.
Could it be the decoder? but why only fault at certain points?
There again the two set loco's with Bachmann decoders work fine on the whole track.
I've checked all wiring for the decoder all looks fine, also tested continuity all fine.
Please anybody any suggestions or help would be great.
Ian
Ian
