1 - 9 of 9 Posts
Two of my freight yard points are going to need surface motors as the they are directly above the table framework. I know you can get surface mounted motors but my question is which ones are best that have the polarity switch as my points are all modded. I will also need to cover them somehow as both are on scene.
Many thanks
Neither the Peco PL13 or the Hornby R8243 surface mounting point motors can have direct fitting switches (unlike the PL10 or R8014).
You could fit micro switches opposite the moving tie bar so as the point is moved over or back the micro switch makes or breaks its contacts?
I have seen a PL13 switch bonded to the underside of a point directly under the tie bar and a Hornby style track pin also bonded into the hole in the tie bar and then passing down through the PL13 to operate it, but it does mean digging out a suitably sized recess in the top of the baseboard to accept the PL13 and wiring.
The only other alternative as is stated by RFS and use a building or removable scenery etc to hide the motor and switch assembly, a bit like this example....
Yes, as stated they do come with an arm fitted.
My one has had the factory fitted operating arm removed and a longer one made up from a piece of Plastikard (that's why its currently white and is pending painting) as I needed a longer reach than the ready made one offered with the PL12
Also the signal box is to be replaced with a Townstreet one as a soon as I have put it together.
1 - 9 of 9 Posts
