I am about to start building the first part of my layout and while I am awaiting permission to use the spare room for 'er indoors I am going to construct a suspension bridge. I have already completed the drawings on AutoCAD, and I am good to go, the only thing now is to decide which materials to build the bridge from. My original idea was to build it from steel strip, 1mm gauge for the bridge bedding and going thicker for the legs and the support stanchions, and then using a pair of condemmed steel rope lifting slings that i have aquired from work. The materials would be welded together in the main part, with self tapping screws and bolts providing other fastenings when welding is a little extreme.
Since completing these drawings however I have been giving serious thought to using timber to build the bridge as it has obvious advantages with cost and weight.
Which method do you guys think would be better for the bridge?
The dimensions are 600mm length x 100mm width x 300mm height, and the means to build it are not a problem as I am a Mechanical Fitter and not too bad with the carpentry game neither.
All help and advice will be greatly appreciated.
Rocket
Rocket
