This item appeared on the Maerklin website. They have managed to get 200 Maerklin locos to pull a full sized DB coach. That would be 1 to 1 scale.
On the area of railways system engineering in Munich took place on 21 February 2007 a sensational experiment. Märklin locomotives of the size H0 on a scale of 1:87 should pull an original-size IC region car of the German course AG over a distance of 10 meters. The car had nevertheless an unloaded weight of approx. 48 tons and measured scarcely 27 meters. 200 Märklin locomotives of the BR 143 with the article number 37433 were available. On 50 tracks, to 4 locomotives each arranged, they were supplied by 50 transformers with energy. To set 3,000 VA necessarily around the IC region car in motion. The experiment succeeded and the 200 Märklin locomotives pulled the 1. Class car evenly, strong over of the Guiness book of the records editorship given distance. The Märklin specialist of the 1. Märklin model course team shifted altogether 625 meters of the Märklin of C-track, pulled 1.5 km cables and set over 3.000 soldered connections. The pool of broadcasting corporations transmission "W wie Wissen" sends the pictures of the preparation and the world record travel on coming Sunday, 25 February 2007 in the 1. Program at 17.03 o'clock.
So if the coach weighed 48 tons and there were 200 coaches, does this mean that each loco was pulling a quarter of a ton?
