I use the Tillig HO/HOe track. It is very good. I use the shared track here as a programming track for my DCC system so I can program the HO/OO locos and the HOe locos in the same place. The programming track can be switched from programming mode to normal DCC so locos can drive on and off.
There is sometimes a problem with shorts on the adaptor piece (above) if both the HO and the HOe lines are powered up at the same time so I use a switch to switch between the two. The downside is that I can't have HO and HOe locos running at the same time on this piece of track, but it isn't a problem.
You can see the switch lever sticking up between the exit rails of the HO/HOe adaptor.
Regarding connecting Tillig to Peco, I have done this in a few areas. I shim the Tillig track with card and stick everything down with PVA. I use a long piece - about 20cm, then a shorter piece - about 7cm, to build up the 'ramp' from the shorter Tillig to the higher Peco. Make sure the rail tops are level and the inner faces of the two types of rail are lined up.
