I hope I am posting this in the right place. Please move, if not.
For the last two years, I have been working on an integrated, on-board camera to give a ‘driver’s view’ of the track. Before I start production, I would like to gather views on what I have done and what could be improved. A bit of background, first:
The usual solution to a track view, is to buy a ‘GoPro’ or cheap camera and place it, either on the top of a locomotive or, more usually, to place the camera on a flatbed truck and push it round the track. Also, most of the solutions require that the user records the video on the camera itself, remove a micro memory card and transfer the memory card to a computer for viewing. The former seems ugly to me and the latter is inconvenient. My solution to these points is to build the camera in to the locomotive itself, keeping it as discreet as possible; and allow the user to view and record directly, in real-time, to their smart phone/tablet. As far as I know, it is the first fully integral camera for oo or larger. The product I intend to sell is the built-in camera AND the locomotive TOGETHER (though selling a ‘kit’ is an option).
Its features:
High quality camera - 2560 x 1920 pixel resolution on a 5mp camera. This is more than twice the quality of some cameras and many times the quality of most cameras.
Self-contained - no ugly wires or external cameras. This is very important to me, as I want the loco to be as original as possible.
Integrated - the camera is very discreetly built in to the bogey of the locomotive. It’s hard to see, unless you are looking for it.
Small - the camera casing is 5.5mm in diameter.
Track following - the camera looks where the train is going. As the camera is attached to the bogey, the camera is following the orientation of the bogey, unlike other cameras that are fixed to the body and so do not ‘anticipate’ the bends. It means that it’s more like standing on the train, and naturally looking at what is coming up ahead.
Holdover battery - the video continues, even if power is removed. The camera is both rail and battery powered. Each backs up the other.
No external charging required - the battery is charged from the track. I have seen solutions where the entire truck is picked up and plugged in to a USB power source to charge the battery.
Analogue or digital - no changes required. The circuitry has been designed, so that it will operate on DC or DCC without hardware changes.
Watch the video in real-time on your smart device - android and ios. No need to manually transfer files from the camera to the computer; or buy a separate receiver, which then plugs in to a television. Most of us have mobile phones or tablets. It could also be displayed on a monitor or TV.
Built-in Wi-Fi – The train acts as an access point or ‘Hot Spot’, so the smart device connects directly to the train. As there is no need for a separate Wi-Fi hub, which is perfect for exhibitions.
Record the video or take a photo on your smart device. The app records video and photos very simply. You can also view them through the smart device.
Simple app and setup.
No memory card required.
So (finally), to the point of the post. I would like to carry out a short survey on what you would like to see in the product and what is (and isn't) important.
Thank you very much for your time to complete this and apologies for the length of the post.
I have attached photos and a link to video from the train and a few photos of the train itself for thoughts.
Its features:
- Is the locomotive with an integrated, discreet camera and real-time feed something that you are interested in?
- For the integrated camera:
- Assuming you are interested, do you want a camera that you can install yourself (requiring modifications to the locomotive body) or do you want to buy an ‘off-the-shelf’ solution?
- Assuming off-the-shelf, should the locomotive itself be inexpensive, to keep costs down, as it is ‘only the train with the camera’; or be more expensive, as you want it to be a ‘feature’? Please give examples of which models you would like to contain the camera.
- What would you use the video/photos for?
- Of the numbered features above, which are the five most important?
- Any other comments or thoughts?
