I have several Triang and Hornby trains from the 70s where the drive wheel slips and I suspect the cog is worn and needs replacement but I can't seem to find advice how the cog, wheels and axles are removed? Does anyone have any pointers and what tools are required? The axles run through the cast body in both-
Thanks - Any pointers appreciated as I would love to get these 2 going again as they were my first trains as a kid. Cleaned up motors etc and therly run fine apart from this. I am also wondering about spacers to stop the movement but in the axel cases I need to get the wheels off, or am I just missing something?
- Hornby Flyings Scotsman. This only seems to run in reverse and the drive gear is worn. The motor turns in forward by the armiture seems to slip up and down on the shaft switching direction.
- 0-4-0 Triang red engine with silver dome 25550, the drive gear moves longitudinally slight along the axel as it runs and looses drive to worm gear. The teeth look slightly worn.
