Hi Guys,
I am new to model railways, and in my 63rd year, the last being a Triang Standard Grey Track Set in the mid 1950's.
I am at present building up a Triang layout from that era of the Standard Track, and have more than enough track, trains, and accessories to build an 8x4 layout, of which the base has been already built, and splits into 3 sections for easy transportation.
I have an Hammant and Morgan Duel controller, but to keep as much of the layout as original as possible. I also have a Triang P5 Power Controller which has fault and would like some help in rectifying the fault if possible.
I have power from the 12v DC Uncontrolled output, and the 15v AC Output.
Sadly, there is no power from the 12v DC Controlled Output, which I need to run the trains.
When putting a meter on the Output connectors it does have a reading of power just in one place just after the neutral position when I turn the speed control to forward. Turn the controller a bit more and the power is gone. In reverse there is no power at all showing on the meter.
Years ago I would have known somebody whom I could have taken it to, and with their knowledge would have worked out of how the Power Controller works, and most probably could have fixed it.
Can any body help, in advising what the fault may be, and is it possible to fix it, and where.
I live in Cornwall.
Thanks.
I live in Cornwall.
Thanks.
