QUOTE (Dave Saunby @ 21 Aug 2013, 18:21)
<{POST_SNAPBACK}>Thanks for all the info on couplings.
Next question.
I am thinking about raising the std grey track with Triang piers and sidewalls, from about midway down the outer edge of my 8'x4' baseboard, over a girder bridge around the top edge, and then back down the other side to continue the rest of the outer loop on the base.
Please could anyone tell me approximatly how my piers and sidewalls I would require to complete this task, and is it very successful regarding stability, and with the engines having to pull uphill?
I am using R106 outer radius curves on the top and bottom ends, with std curves on the inner line of my double track which runs around the perimeter of my baseboard.
The original Tri-ang Railways R.79 Incline piers have the lugs to locate Standard Track. The incline piers also have the top at a slight angle, and so have to be used the right way around. It is usual to have a pier at every track joint.
They come as a set, I think I remember there being 6 piers in the R.79 set. There is also the High Level Piers, which are "flat" on the top, and are the same height as the bridge deck of the Girder Bridge when mounted on the Tri-ang Bridge Piers. (Also the Gravity Unloading Bridge when mounted on the arched bridge piers.)
It is recommended that as much of the upward incline is on the straight, as the incline is quite steep. It is however as designed at Margate!
The Standard Track sidewalls are the same length as the track sections, so you will need a pair for each track section.
The straight ones are the same for both sides, the curved ones come as an inner and an outer. There are no middle sections, as Standard Track is solid.
A complete incline with walls is quite rigid, and the piers are designed to be pinned down to the board ...and looks quite good too.
The outer or second radius walls are the harder to find, as they were not made for as long as the others...
