Triang Railways
41700 Views 136 Replies 25 Participants Last post by  Fred Nitschke
Hi Guys,
I am new to model railways, and in my 63rd year, the last being a Triang Standard Grey Track Set in the mid 1950's.
I am at present building up a Triang layout from that era of the Standard Track, and have more than enough track, trains, and accessories to build an 8x4 layout, of which the base has been already built, and splits into 3 sections for easy transportation.
I have an Hammant and Morgan Duel controller, but to keep as much of the layout as original as possible. I also have a Triang P5 Power Controller which has fault and would like some help in rectifying the fault if possible.
I have power from the 12v DC Uncontrolled output, and the 15v AC Output.
Sadly, there is no power from the 12v DC Controlled Output, which I need to run the trains.
When putting a meter on the Output connectors it does have a reading of power just in one place just after the neutral position when I turn the speed control to forward. Turn the controller a bit more and the power is gone. In reverse there is no power at all showing on the meter.
Years ago I would have known somebody whom I could have taken it to, and with their knowledge would have worked out of how the Power Controller works, and most probably could have fixed it.
Can any body help, in advising what the fault may be, and is it possible to fix it, and where.
I live in Cornwall.
Thanks.
81 - 100 of 137 Posts
Not too different from my Triang railway of 1957 as a 13 year old. I did not have as much rolling stock or a turntable but your model certainly brings back memories. Also at the time I had a mix of standard and Series III track.
Sadly I have no photos of mine.
You have certainly managed to get a lot in the space you have but I guess the 13.5inch radius curves help!
Good luck with the exhibition.I am sure it will be well received.
WOW David that really looks excellent mate. Very well done and I believe you will get loads of interest from the general public as well as the model railway enthusiasts
Good luck.
Thanks for your very kind comments guys and gals.
Once I have made the final adjustments and totally happy with the layout, and because it is not screwed down, it will be broken down, and each piece of the track will be number marked underneath for the 3 ground circuits in red, blue and green marker pen so I know exactly where each piece of track goes, and then taken apart in 3 to 4 piece sections and stored in a long storage box's using bubble wrap to protect the lengths.
The elevated section, will be marked with a black marker pen.
To re-assemble, all I have to do is to take the track lengths out of the box's, and re-assemble in reverse order, and hope and prey that it all goes together.
I will also draw a layout plan, and take photo's of the layout in sections to help in the reassembly.
Very nice Dave, well done. To complete the picture at the exhibition, you need to be properly attired of course, tweed suit obligatory, pipe optional...
(Hornbyguide.com)
have a good time
Really excellent.
If you ever come across them, you might want to add the R170/R171 electrically operated double track level crossing and the R135 operating ore wagon set, both of which started off as Standard Track operating accessories.
When you exhibit it, you might like to remind people that the company is still very much alive in its Hornby Railways guise, as I am sure that most people think the modern Hornby Railways range is descended from the old hornby Dublo range when nothing could be further from the truth.
Thanks Keith.
I have yet to add the backboard which should put the "icing on the cake" of my layout.
I will post pictures in a couple of weeks when completed.
Dave.
Gavin,
I don't have a tweed jacket, but I may have a cardigan!!!!
I had thought I had finished, but there is one outstanding item I would like to acquire.
Can anyone please recommend an Audio CD of British Steam Train sounds that would compliment my layout, from doors slamming, guard and engine whistles, pulling in and out of stations, pulling up gradients, and at full speed etc.
I may not get all that I am asking for, but there must be a CD somewhere on the market that would fit the bill.
Any recommendations and suppliers would be greatly appreciated.
Hi Dave.
You may be aware that Tri-ang Railways released a sound effects record.
"Railway Rythym" was a 2-sided vinyl EP.
One day I'll get around to making a CD of the copy I have.....
(OR, see the PM I just sent...)
QUOTE (lmsboy @ 23 Oct 2013, 20:22) <{POST_SNAPBACK}>Very nice Dave, well done. To complete the picture at the exhibition, you need to be properly attired of course, tweed suit obligatory, pipe optional...
(Hornbyguide.com)
have a good time
Hi Gavin.
That's the "Series 3" Track Train Set Box Top picture. ( I think it is one I supplied to the Hornbygude as well...
) C1958-1962
Here is a couple of "Standard" Track pictures...
Very early 1950s. Spot the roller pick up Princess Locos! The buildings are the original "mock-ups"!"
Later 1950s...with the first Series buildings...
A special for those who wonder what the original Rovex track was like...
Brass rails, and "Non-Universal". The sections can be joined only one way around. Fine for a simple train set oval, but not so good for a "system"!
Tri-ang re-tooled the track to make it "Universal" (It can be joined any way around), the original name for "Standard" track. It was known as Universal, then plain Tri-ang Track, until Series 3 was released in 1958, when the name "Standard" was introduced....
Yes takes me back to the great days of the mid 60s when my Mum and Gran took me to lewis's in Glasgow to see Santa, this was followed by a visit to their toy department where there was a Triang display layout. Just like yours although I think using super 4 track by then. I remember one circuit was at a higher level. Probably relatively simple but to a wee boy it seemed huge. Your layout just brings these memories back. Thanks for that
My first train was the Triang Freightmaster delivered by Santa in 1965. swiftly followed by a Jinty and in 1966 Santa arrived with the Triang AL1 electric, because it looked like these new electric trains around Glasgow(well it was the same colour!). Hours were spent browsing Triang-Hornby catalogues,looking at layouts and marvelling that someone could have such a large layout. I still run the old trains on my layout although the AL1 is pretty knackered.
Thanks for bringing it back
Russell, wallowing in nostalgia
Thanks Russell for your kind comments, and re-kindling memories of your boyhood, which really is what my layout is all about.
QUOTE (rb277170 @ 28 Oct 2013, 18:56) <{POST_SNAPBACK}>Yes takes me back to the great days of the mid 60s when my Mum and Gran took me to lewis's in Glasgow to see Santa, this was followed by a visit to their toy department where there was a Triang display layout. Just like yours although I think using super 4 track by then. I remember one circuit was at a higher level. Probably relatively simple but to a wee boy it seemed huge. Your layout just brings these memories back. Thanks for that
Hi Russel...
Here is something I think you may like...
Tri-ang Railways RS.51 "Freightmaster" Train Set...1965 version!
QUOTE (sarah @ 30 Oct 2013, 10:24) <{POST_SNAPBACK}>Here is something I think you may like...
I know I do
Russel,
You may like this also, and decide to open your wallet - no idea what it's really worth or who/how many may be interested, but you might be lucky
The FreightMaster - yours for the bidding!!!
You brought back memories there mate. We only went a few times a year to Glasgow when I was a kid. But the main event was the Christmas trip and the visit to the real Santa. None of the others were real just the Lewis's one. And all the window displays some animated. And the walk to Santa's grotto was a long corridor full of other displays. Where has it all gone.
Here are some more pics of my layout at different angles, and without flash.
Hope you all enjoy them.
You certainly have a good collection there...
Very nice.
(Like you, I have a shortage of R11/R.14 Van Roofs!
The first British mainline diesel produced by Tri-ang Railways, D5578 Brush Type 2.
