Triang wire diagram
9451 Views 14 Replies 5 Participants Last post by  Basil
hey all ive not long joined this forum but been into the hobby for a number of years and recently i been given some old triang locos about 15 in total expect for a few which the wiring had been ripped out of them i tested the motors which run like new and was wondering if any one had or knew of a diagram so i could rewire them to work
many thanks dave
1 - 15 of 15 Posts
thanks for that could i rewire it with out the tv surpresser on it
QUOTE (falroadman @ 15 Jun 2008, 00:26) <{POST_SNAPBACK}>thanks for that could i rewire it with out the tv surpresser on it
think the answer to that is yes, hope you got good neighbours.!!!
The Suppressor capacitors are usually around 470pf (picofarads). Triang used to use ceramic ones as they were robust, small and reasonably cheap. But any capacitor of that size and around 50 volts working voltage will do. Maplins and the like should be able to supply them.
Do do a search on this site for 'old motors' or the like; some very useful information has been published here regarding getting old Triang motors running smoothly.
QUOTE (poliss @ 14 Jun 2008, 22:50) <{POST_SNAPBACK}>Lots of Tri-ang service sheets at this link. http://www.modeltrains.net.au/hornby/service_sheet_menu.asp
Great website for the database and pointers to correct model numbers etc to track down the model.
And you might try downloading direct from Hornby for the actual service sheets (very good but incomplete list of service sheets on the hornby site)
Any chance you (y'all) might know where to get Hornby Dublo service sheets as I need them to fix a couple of old locos. Nearly done but still some fine fiddling to go and service sheets help.
(and any others , I need a TRIX 0-6-2 and mainline 4-6-0 chassis service sheets as well)
I am searching the web but nothing yet
I may start a thread on this one (moderators ??)
Your wish is my command Basil. Here they are. http://www.mtrains.co.uk/3.html
Which Mainline 4-6-0 do you have? Is it the ex-Airfix Castle? Service sheet here. http://www.airfixrailways.co.uk/ARSCastle.htm I'm sure I've seen British Trix somewhere. I'll keep searching.
QUOTE (poliss @ 15 Jun 2008, 16:36) <{POST_SNAPBACK}>Your wish is my command Basil. Here they are. http://www.mtrains.co.uk/3.html
Poliss,
Many thanks and I have come across this website but missed the service sheet area (D'oh)
I have also been in touch with them and got some spares on the way.
I will be making some 'arty' type locos (variation on the 'Thomas' theme) using Hornby Dublo metal chassis(es) and will post the result at some stage. It's for the kids of course.
In answer to your post below, I have a patriot class Bachmann loco body and a mainline 4-6-0 chassis (perfect fit though not purist stuff) and have myself a nice loco for my eventual but currently virtual layout. For you aussies, it is a loco body named 'Western Australia). There's a picture at this post with the link below.
http://www.modelrailforum.com/forums/index...amp;#entry55009
I tried setting up a blog (but I broke it as in 'I doesn't work - Help administrators, Please take note and delete my current blog)
I have the service sheet for the bachmann chassis but not the mainline (and already ruined one motor by loosing one of the springs and brushes)
Many thanks for your post
Onwards
The new Mainline website doesn't have the service sheet for the Patriot yet. But I would keep checking it. http://www.mainlinerailways.org.uk/Introduction.htm It's run by the same man who does Tri-ang, Airfix, Kitmaster, and now Wrenn.
I haven't been able to find any service sheets for Trix locomotives. :-( Maybe these people could help. http://www.ttrca.co.uk/
QUOTE (poliss @ 15 Jun 2008, 17:48) <{POST_SNAPBACK}>The new Mainline website doesn't have the service sheet for the Patriot yet. But I would keep checking it. http://www.mainlinerailways.org.uk/Introduction.htm It's run by the same man who does Tri-ang, Airfix, Kitmaster, and now Wrenn.
Poliss,
Many thanks again.
Will check these out.
and post the url when the patriot does come out (Hope someone from mainline sees this)
Service notes for trix is at the following site and are available as pdf and word. They are not the original ones but very good for detailing parts etc. Spareas are also available from this site.
I will post more info as I get it
http://www.ttrca.co.uk/Spares.htm
The mainline site is also very good but no service sheets but lots of helpful notes and diagrams.
There's also this Trix website. http://www.trix.co.uk/
thanks everyone their finally repaired and in the process of having new paint jobs
will put pictures up as soon as possible
quote name='poliss' date='15 Jun 2008, 21:56' post='55334']
[/quote]
Thanks Poliss. I will check this out
Train Toy Rectangle Engineering Auto part
I am still looking for a suitable chassis and motor for this old Trix and have begum work on the Hornby Dublos. I will probably add a post to the 'On my workbench' to follow on from
http://www.modelrailforum.com/forums/index...?showtopic=5520
The hornby dublo is an interesting type of 'open' motor construction. Meaty stuff !!!! The complete one was got from 'Mainly trains' and the bits and pieces have arrived to fix up the other chassis (the other one will be scrapped after being taken apart)
Automotive tire Wheel Tire Camera lens Motor vehicle
Fun occurs in a variety of ways
1 - 15 of 15 Posts
