1 - 1 of 1 Posts
Administrator
The Deutche Bahn ICE 3 by Trix
Review by Neil Wood
Trix model 22205
Train Vehicle Rolling stock Bullet train Electricity
Many railway modellers prefer steam engines to modern diesel and electrics. There are several reasons for this like character and nostalgia; however for younger people the trains that catch the eye are the modern express trains. Nothing defines the advances in locomotive technology better than the high speed trains now operating in Europe and Japan. One of the latest of these is the ICE3 which made by Siemens in Germany.
The ICE3 is the third incarnation of ICE with substantial modification from the previous two versions. A higher top speed of 330km/h and the ability to climb steeper grades required greater power than the previous versions. The power was to be distributed across the train rather than concentrated in one or two power units. The ICE3 will be an eight-car `half train' with 16 powered axles which can operate in double traction like the ICE2.
Testing of first ICE3 vehicles began in autumn 1998. The first ICE3 trains were delivered to the DB Reise &Touristik AG and NS Reizigers BV towards the end of 1999 and entered regular service in May 2000.
The ICE1 and ICE2, were intended for domestic service, however the ICE3 comes in versions for one and four current systems and has a slightly narrower profile for international operation throughout continental Europe . The international ICE3 will be delivered with the signalling systems of the Netherlands , Germany and Switzerland , but can be easily extended to run in other countries ( Belgium , France , Italy ) as well.
37 single-system trains (class 403) and 13 four-system trains (class 406) are in service or still being delivered for the DB AG. 4 four-system trains (class 406, NS number 4651 to 4654) have been delivered to the NS.
The styling was created by Alexander Neumeister, who is responsible for the visual characteristics of the whole ICE family. The carriages are shorter and narrower than those of the ICE 1 and ICE 2. The front is more streamlined, and instead of the two rectangular front windows, it now has one large oval window. The passengers in the first and last car can look out through the cab window.
Train Vehicle Rolling stock Bullet train Automotive design
Series 1
e.g. Bistro concept
Series 2
Single system
Multi system
Single system
Year
2000-2001
2000-2001
from 2004
Number of cars
Power system [kV/Hz]
AC 15/16.7
AC 25/50
AC 15/16.7
DC 3
DC 1.5
AC 15/16.7
Maximum power at
wheel: [kW]
at AC
at DC
8000
8000
4300
8000
Maximum speed: [kph]
at AC
at DC
330
330
220
330
Track gauge [mm]
1435
1435
1435
Number of seats
441
431
458
Number built
Germany
Netherlands
37
13
Material property Font Rectangle Metal Stationery
The Trix ICE3 model 22205
Released; Jan 2005
Price: 599
Extra coach models 23397, 23398 and 23399 Released: August 2005 Price: 72.50 each
Model Specification:
Length: 1422mm;
Type: Class 403;
Livery: Deutche Bahn;
Period: Current;
Features: Front and rear directional lighting, Interior lighting in all coaches, NEM couplings, DCC sound decoder installed with operating sound effects, includes diode plug to enable conventional operation, mechanically operating pantographs (do not work electrically); Finish: Pristine;
Motor: 5pole motor located in dining car.
The Trix model 22205 contains;
  • 1 Type 403.1 End car
  • 1 Type 403.1 Transformer car
  • 1 Type 403.3 Dining car
  • 1 Type 403.6 Transformer car
  • 1 Type 403.5 End car
The Trix extra Coach models
  • 23397 is a Type 403.7 Power converter car;
  • 23398 is a Type 403.8 Intermediate car;
  • 23399 is a Type 403.2 Power converter car, 1st class
Train Automotive lighting Rolling stock Automotive design Grey
This is a beautiful model. It encapsulates the sleek lines and parallels the technology of the original. Unlike most other models this requires no modification. It already has a decoder with sound and lighting. The sound effects circuit has sounds of doors opening and closing, station announcements in German and English, engine running sounds and horn. The acceleration and braking delay can be minimised digitally.
Building Nature House Vehicle Urban design
The starting delay allows a realistic pulling away speed. The engine powers up and the loco slowly starts to accelerate, the model then takes off. It hugs the track very well. It maintains high speeds even round narrow bends. It has metal inserts to give it a low centre of gravity. I run it around the inner tighter loop on my layout and it has never derailed even at high speed. Unlike most Trix models this is made of plastic rather than metal. The coaches are connected by a 6 pin connecter. The power pick ups are in the end cars so the power has to be transmitted down to the decoder and motor. For this reason no other coaches other than the Trix coaches are compatible with this product. Three extra coaches are available to add to the basic five car consist. The manual says that seven cars can be run in total. Given that I am currently running it with seven coaches and is running extremely fast at half power, it could easily take eight.
Train Vehicle Rolling stock Public transport Railway
The only negative factor I have found is that, due to the type of electrical connection between the cars and the amount of cars this has to go through, the track has to be well connected and have a smooth transition between gradients. If the transition is too sharp it can cause a break in the electrical connections between the cars. When the current is broken the decoder restarts from the initial settings, which means a delay before it powers off again. Once your track is sorted out it runs smoothly and efficiently just like the real thing.
Train Vehicle Rolling stock Bullet train Building
I have to admit a bias towards express trains. For much of my life I travelled on the GNER 225 from Kings Cross to Scotland . I loved the journeys and when I returned to railway modelling, one of the models I most wanted was the GNER 225. When I did get it I was so disappointed.
While Hornby were upgrading and detailing many of their locomotives this one had been forgotten. I had bought four additional coaches for the train and it could barely pull them on the level as the motor was so weak. Why do I mention this? Because this Trix model is everything the Hornby was not. It races along at high speed with seven coaches instead of struggling. It has highly detailed moving pantographs rather than a sad simulation.
Train Plant Rolling stock Electricity Locomotive
Trix pantograph
Yellow Trigger Electric blue Automotive exterior Bumper
Hornby pantograph
All coaches are fully lit. The front and tail lights change over with direction and it has several realistic sound effects. This model led to me dropping British railway modelling completely for a couple of years. The contrast is stark between the two models. You could say that it is not fair to compare the two models as they are so differently priced. Well Hornby list their GNER pack at ₤99 with three coaches at ₤20 which comes to ₤160 then add a sound decoder for ₤100 and youre at ₤260, add on lighting for the front and rear at ₤18 each plus coach lighting costs and youre getting close in terms of overall cost. But look at all the work you have to do and thats assuming you are capable of undertaking it. Look at difference in terms of detail between the two even with all the other modifications. You would have spent the same money to modify the GNER as to buy the ICE 3 and it would still be lacking in details. Nothing could underline more the difference between a budget model and a high quality one. Some modellers may not care for all these extras. If not, then this clearly is not the train for you. Mehano do a budget version of ICE3 for ₤135 which has none of the features of the Trix loco. This locomotive is for the modeller who wants the latest, most modern, technologically advanced available. This model really is ready to run. There are no further modifications necessary. If only Hornby could have made a GNER 225 like this.
Train Vehicle Rolling stock Automotive design Mode of transport
Detail from front of Trix ICE 3
Automotive parking light Vehicle Automotive lighting Van Motor vehicle
Detail from front of Hornby HST
Train Vehicle Rolling stock Bullet train Mode of transport
This model is a big favourite with my son and nephews. Its the one they ask to see run first. It sleek modern lines make it very popular. While many love the older steam trains, this is the future. This is what gets younger people interested in railways. This is state of the art technology in rail; both in real life and in model. I like most trains, both older and modern, but I have to say this one is one of my favourites. I love its speed, looks, and its high powered sounds as it races along. So is it worth 599? Yes it definitely is although you could buy it for less if you shop around. I would certainly recommend it. Youll love it.
Programming table of the most important CVs
CV
Designation
Area
Factory setting
Loco address
1-127
Starting voltage
1-75
Braking time
0-64
Top speed
0-64
63
Middle speed
0-64
25
Basic setting
Expanded loco address
128-9999
0
29
Configuration register
0,1,2,3,4,5,6,7,32,33,34,35,36,37,38,39
Expanded configuration
2,3,18,19
19
63
Noise volume
0-64
64
Neil Wood - May 2006
1 - 1 of 1 Posts
