I've found this kind of information quite hard to pin down for the larger scale turntables we're designing - there are so many different types - light, heavy, wide, narrow, shallow, deep, and some downright agricultural. The best thing is to get a photo of the particular type that interests you and try scaling it. I see you are in Aberdeenshire, so if you haven't already tried it, it might be worth going over to Aviemore to take some dimensions off the working turntable there. It might be a bit bigger than 54 ft, but it should be a good guide to the general proportions. It's relatively modern (post war) and I think it came from Kyle of Lochalsh, so it would have been sized to turn a Black 5. Also, I wonder if the GNoSR turntable pit is still there below Union Terrace Gardens in Aberdeen? You could still see the remains of it last time I was there, and there might be enough left to give you some ideas.
Maybe you can let us know how you get on with it. The 4mm scale manufacturers only seem to like the largest turntables, so those of us who want the medium ones have to build our own.
