Twinwoods & Bedford
1773 Views 21 Replies 4 Participants Last post by  Ruud Boer
Twinwoods & Bedford - 01 - Layout Design
Together with hobby friend Nico the plan is to build a new layout in a spare bedroom. In this thread we like to post progress from time to time. We’ll go through all the steps, from first ideas, to design, to (3D) simulation, to woodwork, to track laying, mount point servo’s, add train feedback and create computer control. The plan is to add some videos along the way too.
No scenery in that list? Well … to be honest, creating beautiful scenery is not our forte. To us the emphasis of the hobby lies on the design, woodwork, track laing and then the automation. We’ll probably drive around with too many trains on too much track to make it look like anything ‘real’.
This is a link to video 01 - Layout Design
These were our criteria:
  • Available space: 4040 x 3700 mm
  • Scale: HO
  • Rail: Peco OO 75
  • Minimum radius: 600 mm
  • No need for much scenery
  • We like to have a lot of rails
  • It doesn’t have to resemble real world
  • We like to be able to drive around on a loop
  • We also like to drive dead end to dead end
  • We like to have a train viaduct, it enables a longer available track in the same space
This is the end result of our design efforts:
  • Like
Reactions: 1
1 - 20 of 22 Posts
Twinwoods & Bedford - 02 - Table Design
The track layout has round shapes. We like the tables to follow these rounds. This means a lot of saw work, with good accuracy.
The plan is to first draw the table lines on the wooden plates such that it’s easy to follow them with a jigsaw. We’ll first make a drawing with the correct dimensions in Fusion 360. Using a 10 cm grid we can transfer the table coordinates at the grid intersections to the wooden plates, on which we first also place the grid dots. Then we play ‘connect the dots' and we'll have the real size drawing on the wood.
The plus of using Fusion 360 is that once we have a drawing we can simply turn it into 3D shapes and get a good feel for how it’s going to look.
Another option could be to print the layout in real size via SCARM. But then to accurately place all A4 sheets on the wood and transfer them to saw lines is still a challenge.
We’re curious what other methods have been used to transfer the layout to the table and create accurate saw lines?
This is a link to video Twinwoods & Bedford - 02 - Table Design
  • Helpful
Reactions: 1
It's interesting to see a design that's operationally all about train movements. (I guess the models used will represent passenger services operated by multiple unit type trains?) Operation is my primary interest, though in a locomotive hauled scenario; and the scenery is minimal, it's all about timetable operation of the trains.
You have all that in the plan. And it is very suggestive of a well known UK railway operation if that matters to you at all! What is amusing from my perspective is that the East midlands station names make a 'false connection', yet there is a location in the UK where such a very dense MU operated network exists. If names like Addiscombe, Brixton, Croydon, Dartford, Epsom, were used, that immediately suggests the appropriate location. South of the river Thames on the densest MU operated network anywhere in the UK. Whatever, your choices are your own to enjoy.
Have fun building it, I have not a clue of how to map that onto the plywood for accurate cutting, being an L girder afficianado, with free hand cutting of the track bed...
  • Like
Reactions: 1
Certainly looks like it could be an interesting layout, particuarly watching trains coming around the loop between Luton and Bedford.
It might be worth considering having a set of storage sidings 'off-scene' below the main layout to enable you to swap/change the stock that is running more easily. This could be accessed via an incline/helix/similar.
<SNIP>
<SNIP>
My two suggestions could be to either approach an outfit that would be willing to CNC-out the baseboard tops to suitable shapes, or using a large-format printer to print off the track plan (and baseboard outlines) on A0 paper - much easier to align than 100s of A4 sheets!
  • Like
Reactions: 2
Thanks for the feedback '34C' and 'kiwionrails'.
The plan is to drive with 12 trains, controlled by Traincontroller, with hand operation or a combination of automatic traffic and hand operation still possible.
2x intercity CW
2x intercity CCW
2x passenger shuttle to all 5 stations
3x cargo shuttle CW to the three dead end areas
3x cargo shuttle CCW to the three dead end areas
As for drawing the saw lines on the baseboards we'll first try a handful of these paper rulers that hang around at large DIY stores. With a multitude of those we can create a grid and we hope we can then place coordinate dots with enough accuracy.
A helix to a lower level is a bit out of our leage right now. Besides ... we don't have more then 12 trains. :)
  • Like
  • Love
Reactions: 2
<SNIP>
....yet... :ROFLMAO:
  • Haha
  • Like
Reactions: 4
Twinwoods & Bedford - 03 - Widen the Aisle
We had performed tests to investigate if we’d be able to pass through a narrow space of 30 cm. The tests were performed with two desks spaced 30 cm apart. The tests were positive, as in ‘it’s doable’, but deks are only 74 cm haigh, which means you pass them below your bum, with your legs. Yesterday we were able to perform similar tests with tables at the intended height of 110 cm … that’s a whole other matter. Now you pass the tables above your bum, with your belly. How come that does not fit nicely anymore? I have no idea. :)
Conclusion of the test was that we need to modify the layout. To create more aisle space we had to give up our criterion of a minimum curve diameter of 120 cm, we made the inner curve around Bletchley station 100 cm and we also created a small bend just after the turnouts into Bletchley. This had the desired result … we now have a 50 cm aisle width.
In the process the idea popped up to extend Bletchley station over the curve, creating a tunnel. This helps make the layout somewhat more interesting. It’s not decided yet … let’s say this has an 80% probability.
This is a link to video Twinwoods & Bedford - 03 - Widen the Aisle
  • Like
Reactions: 3
Good progress in making the layout practical to operate.But what's the blue rectangle beside Bletchley junction? Looks to be near scale for a 50m pool, perhaps for competitive swimmers among the train crews?
  • Haha
Reactions: 2
@34C Lol . yes, look like a pool. :) But it's intended to be a small table surface for the laptop.
  • Haha
Reactions: 2
looks like a very uncomfortable place to operate from I hope you don't get cramp. and you had better stay off the beer and mince pies at Christmas :LOL: looks interesting all the same👍
  • Haha
Reactions: 1
Twinwoods & Bedford - 04 - Simulation with EEP
Before putting the saw into the wood, constructing tables and laying track we planned to do two simulations, one in Traincontroller and one in the very nice EEP 3D (model)railway simulator, which this video is about.
Any possible issues found in this stage will be much easier to resolve than after the tables are mounted and track has been laid. Besides … it’s just fun to create a layout in EEP and have trains run fully automatic, thanks to the additional software that was created in a joint cooperation with German hobby friend Frank Buchholz.
So … what are we looking for? Well, mainly if the layout looks nice … in our eyes that is, some will think there’s too much track and too little scenery, but that’s how we like it :). We also want to check if train flow is smooth, varied, and without any traffic jams or hiccups, or opposite to see if there are any tracks that are never/seldom used.
This is the link to video Twinwoods & Bedford - 04 - Simulation with EEP
For those who like to try out EEP:
This is a link to EEP on Steam.
This is a link to the free EEP Automatic Train Control software.
This is a series of videos on EEP automation
  • Like
Reactions: 5
What a great way to check your track plan works also the overall look with buildings and terrain ect.
  • Like
Reactions: 1
Twinwoods & Bedford - 05 - TrainController
The second test before sawing the tables is to try the layout in TrainController. TC is a Windows program for control and automation of digital model railways. It has a simulator mode which makes it possible to already test a layout before it is physically there.
TC uses block control. Every block has an entry sensor. These can be reed switches operated via a magnet under the train, or current measurement, or other. The sensors tell TC when a train runs into a block. If it has to stop in this block, the brake marker is the point where the train starts to slow down, until it reaches the stop marker. Distances between the sensor and the brake- and stop marker are user specified.
Once the layout has been divided into blocks, ‘Schedules’ can be defined. These specify which trains should drive where. Once the train reaches the end point of the Schedule, TC selects a new Schedule from a list of ‘successors’. This way fully automatic traffic is created, while it still is possible to drive trains manually, in between the automatic traffic.
The test is performed to see if traffic keeps flowing, if there are no hiccups, or deadlocks, or if there are blocks where no train ever comes. All went well … so … it’s time to start sawing the tables!
This is the link to video Twinwoods & Bedford - 05 - TrainController
  • Like
  • Wow
Reactions: 2
Twinwoods & Bedford - 06 - Sawing the Table
The two simulations (EEP video 4, TrainController video 5) showed us that this layout can have an interesting train traffic flow. This gave us the confidence to now start sawing the wooden plates for the table.
The challenge was to transfer the drawing from the PC to the boards to have the lines to saw along. We did this by first placing a grid of boards over the layout drawing. This enabled us to read out the x,y coordinates of strategic points per board. Two points are needed for a straight line, three for a curve. We used a bendable plastic strip to draw smooth curved lines on the board.
This is the link to video Twinwoods & Bedford - 06 - Sawing the Tbale
  • Like
Reactions: 1
Twinwoods & Bedford - 07 - Mounting the Table
After having sawn the 9mm wooden plates in their respective shapes the tables can be mounted.
Along the wall the plates rest on a full length beam. The peninsula and the aisle side of the tables rest on legs, connected via beams to create a support frame. All legs have height adjustable feet.
In the meantime the lower and upper tables and the peninsula are mostly done. What’s left are the two ramps. These will be sawn out of 3mm board because they need to be flexible. The ramps are curved and need to be twisted some to mount them flat to the surface at both sides.
This is the link to video Twinwoods & Bedford - 07 - Mounting the Table
  • Like
Reactions: 1
Making some very good progress there!
  • Like
Reactions: 1
Twinwoods & Bedford - 08 - The Table is Ready!
This week a hardware milestone has been reached: the woodwork for the table is finished.
The bridge that can be opened at the room entrance has been mounted with two hinges on one side and a sliding lock at the other.
The two ramps are height adjusted and supported to the mm. One has a 2% inclination, the other 3%, we trust trains will be able to drive OK on these.
A few pieces of cork layer still have to be placed and then … let the track laying begin!
This is the link to video Twinwoods & Bedford - 08 - The Table is Ready!
  • Like
Reactions: 2
Twinwoods & Bedford - 09 - A Paint Job & Turnout Servo Mount
We experimented with several rail bed and ballast options. We don’t plan to ballast the tracks 100%, which we know looks best, but we’re not that much into scenery and 100% ballasting is going to be a whole lot of work. We think we found a nice compromise that’s a lot less work and which also doesn’t require a second layer of cork under the tracks to heighten it.
The only thing needed is to paint the cork in a dark brown / rusty color, to which later maybe some spots and streaks of darker almost black can be added to taste. So … that’s what has been done past week, the cork has been painted with a Palissander stain.
The first track pieces and turnouts have been placed too, accurate to the mm. The video shows how we do the turnout servo drives.
This is the link to video Twinwoods & Bedford - 09 - A Paint Job & Turnout Servo Mount
  • Like
Reactions: 1
Twinwoods & Bedford - 10 - Turnout Servo Drive
This video shows the servo drive we use on the layout in more detail. The servo motor is an SG90 180°. It fits snugly in a 15mm aluminum U profile, in which two screw holes are drilled as well as a 1mm hole that serves as the pivot point for the pin that moves the turnout. The pin is an unfolded paper clip.
We use Arduino for DCC control, loaded with the MARDEC software that can be downloaded for free from www.arcomora.com. This software is a DCC servo- and accessory decoder and it’s also used to tune the required servo angles for the two turnout positions.
This is the link to video Twinwoods & Bedford - 10 - Turnout Servo Drive
Twinwoods & Bedford - 11 - Laying Flex Track
We use Peco HO 75 track, which consists solely of flex tracks. To lay the flex track we use a couple of helpers like:
  • A carton, cut in a circle of the desired radius, to lay circles
  • A wire connected to a center pin, to lay circles
  • A flexible plastic strip, to mark non circular curves
  • A 15mm aluminum U strip, to lay straight track
  • Different lengths of hardwood, to lay shorter pieces of straight track
  • Track spacing jigs, to lay multi track stretches with high accuracy constant spacing
This is the link to video Twinwoods & Bedford - 11 - Laying Flex Track
  • Like
Reactions: 4
1 - 20 of 22 Posts
