***No, if it is a single motor locomotive you have to fit one large scale decoder.
If it is a 2 motor loco then you could use two with the same address, although you could expect some issues with running problems as its unlikely both motors will be 100% identical in performance.
Either way its better to use a large scale decoder.
You will be absolutely delighted with the performance of the ESU LokPilot XL, as the current version has a fantastic back EMF performance and a backup power supply so it will never ever stall anywhere!
