Oh dear!
From what I remember, you need to press the bottom left hand button to get into the system-menu screen.
I only remember this as I had to re-calibrate the one at Digitrains as the menu exit button wouldn't work (which is down the right hand side)and the joystick wouldn't move left.
If the left hand buttons are working ok, you need to press the bottom left hand button then in the pop-up box there is a list of options, I forget which one it is, I think it says what it is, if not just select each one until the correct screen is shown.
Once you have the correct screen you should be able to choose what you wish to calibrate, the screen or joystick.
The mode button is one of those down the right hand side, as the screen has gone out of calibration pressing the mode button won't do anything.
Funny Digitrains have had a couple now where the right hand side buttons don't work.
They just sent them back, as without any sort of manual it's hard to know what to do.
Having bluffed my way through it by messing about and pressing buttons, it looks like the left hand side buttons may be a datum so that you can always get back into the calibration page.
It's a major problem not having a manual in English that tells you how to do it!
