Water and modelling there of
260 Views 13 Replies 3 Participants Last post by  linka
I love water and the modelling thereof
Wood Gas Hardwood Composite material Flooring
paint base black then add blue and green I prefer darker shades some like lighter shades
paint direction water flows allow different tones to intermingle
Wood Water Wood stain Hardwood Composite material
varnish also in direction water flows
Plant Tree Land lot Slope Natural landscape
reference for water side slope
Road surface Wood Asphalt Building Urban design
foam carved and shaped as per reference
Wood Grass Slope Road surface Asphalt
add static grass, well you can add any grass but I like static, avoid day flo spring colours they rarely photograph well, and in my opinion mix 3 colours, a flat single colour rarely looks right
Plant Bedrock Wood Road surface Grass
make your foam wall, I used a rule pencil scalpel and paint
Water Plant Road surface Watercourse Grass
put together, notice the river is dusty from me making the slope and wall, you can hoover I prefer a brush then a damp cloth
Plant Window Building Land lot House
add a tree or two
Water Sky Plant Cloud Tree
Water Water resources Plant Road surface Watercourse
always refer to a prototypical photograph reference in my opnion
  • Love
Reactions: 1
1 - 14 of 14 Posts
Wall should be under a different thread but used here so
Road surface Wood Asphalt Brick Brickwork
Hood Automotive tire Automotive exterior Vehicle door Plant
I literally scored it metal ruler and scalpel then painted theh sealed with thin pvc glue and added some ‘grass’
  • Like
Reactions: 2
Tip if you ‘water’ gets dusty so photographs badly hoover or brush off then use a damp sponge, 2. Picks up dust 3. Leaves an excellent sheen when photographing
when I want a good look I do a refresh the water helps with reflections
Water Plant Water resources Natural landscape Fluvial landforms of streams
tip to get the reflection higher then lower the camera and angle slowly up then down until between the 2 you get the result you are after….simples
  • Helpful
Reactions: 1
Oh yeah if you photograph whilst varnish is still wet you get sone total brilliant pictures.
talking of varnish it has a number of unusual properties, I prefer the old fashioned stuff preferably honey coloured, not that it is sold as honey it is sold as clear, I avoid the plastic varnish nasty nasty stuff.
tral varnish also has a property that allows you to make real ripples! Make a layer dry, make a secon layer let almost dry add a third layer, preferably on a warm day the two top layers dry at different speeds and it adds natural ripples
fyi even when you know this ‘trick’ it is not a slam dunk, if it fails repeat and you are almost certain to win on a 50/50 basis
Water Plant Window Vehicle Car
Water resources Water Road surface Watercourse Tree
the ripples here were enhanced by modelling water glue which is stiff but mostly this is varnish layers, I add white paint afterwards for the white foam effect
Water Water resources Body of water Watercourse Bank
light especially natural light across picks up in the glue/varnish with an excellent copy of the real thing, if no natural light a torch can imitate with a little bit of playing about
Water Mountain Watercourse Mountain range Landscape
these honey tones are my preference
Water Window Vehicle Tire Wheel
Fig / smoke is teased cotton wool
lily pads are paper cut and painted green set between varnish layers
  • Love
Reactions: 1
Weir
Water Wood Trunk Watercourse Grass
Water Plant Natural landscape Fluvial landforms of streams Bedrock
weir still a work in process but been halted for a while
Plant Natural landscape Road surface Wood Branch
green and ballst used to ‘ground the wall to the water
Plant Water Wheel Vehicle Tire
Plant Twig Tree Art Rectangle
Plant Wood Natural landscape Tree Water
ballasr added between layers, white added with cocktail stick while varnish is wet
Water Wood Natural landscape Road surface Grass
Water Vertebrate Bird Wood Watercourse
my water birds are metal and do not have great heads so I usually turn them away
Water Road surface Wood Wall Asphalt
Plant Wood Twig Tree Trunk
making the trees
copper fine twisted coated, many options I prefer one that does not crack when bent then painted
  • Like
Reactions: 1
Water does not need to be large expanses
puddles, my first puddle was correcting over cutting a road which was too deep to pull it back up I added ‘water’
Water Window Road surface Building Asphalt
Road surface Asphalt Automotive tire Grass Tints and shades
Plant Tire Wheel Automotive tire Tread
Wheel Car Land vehicle Tire Vehicle
Car Vehicle Building Automotive lighting Window
  • Love
Reactions: 1
Neither does it have to be horizontal, vertical is more of a challenge but worth the effort
waterfall
Water Water resources Wood Bedrock Watercourse
it takes a while to build up
ug well worth the time, this took me about 3 months
Water Bedrock Body of water Watercourse Natural landscape
Mountain Bedrock Terrain Natural landscape Formation
Water Plant Nature Bedrock Body of water
Water Water resources Natural landscape Bedrock Plant
Water Plant Bedrock Watercourse Landscape
Wood Water Bedrock Watercourse Trunk
Bedrock Wood Trunk Natural landscape Outcrop
Mountain Highland Plant Natural landscape Grass
  • Like
Reactions: 1
water I wanted a dynamic water feature and decided a car racing through water might be fun
this area looked viable
and I got to work with enthusiasm
I wanted more splash
and more and thought the car should be wet
ummm about that point I may just have got a bit carried away
I modelled it on the cotton wool with pulled that off once dry
then set it in position
added some paint to try and emphasise the 3d
yeah I definitely got carried way lol
even adding a figure trying to escape
the vehicle is from the professionals so the runner is a villain trying to escape
I made it quite thick to make it strong and self supporting but lost the look through dynamics of the water
i certainly enjoyed the journey but in the end I was not convinced it worked
still nothing ventured nothing gained
  • Like
Reactions: 2
Hi Jaz,
That’s sequence of pics has made me chuckle,
Did really like the first wet / puddle road scenes as previously posted too.
But the tidal wave is so funny, maybe needs one of these, your fav after all squeezed into shot or a surfer a top or in the barrel of the wave even -
.... great fun, keep it up, Happy Modelling, Cheers Norm
  • Love
Reactions: 1
[/QUOTE]
Very true
  • Like
Reactions: 1
Hi Jaz,
Oh I have it no smiley face but yep I should look at that lol
in fact I have 2 choices for the van, I can cut out a surfer board or two lol, I just need a stood up figure to stand on it,may need to cut a limb or two ….and maybe a reference picture 😂 lol
it would look brilliant on the cove….hmmmm definite potential! Thanks for the idea :D
  • Like
Reactions: 1
Ok we have some prototypes!
  • Like
Reactions: 1
1 - 14 of 14 Posts
