As with all building materials concrete has a vast range of colours depending on what it's used for. Road surfaces tend to be cream in colour, which 1960's tower blocks are grey. Best advice would be to get loads of photographs of your desired concrete structure to get the right shade.
Once you've got that, next thing is surface texture on the structure. Concrete is never perfectly smooth. On structures I've scratch built, I give the surface a very thin skim of decorators filler, which is rubbed down after dry to get the required finish. Again research is important here. Old concrete will be more 'weathered' then new. It will also have chipping along edges and may even have signs of crack repairs or have rienforcing rods exposed. Also consider scale here. What looks good in 'OO' would be way too course in 'N'.
Once repeared, paint the structure in the desired colour. Once dry, give the structure a wash of a darker colour to pull out the surface imperfections and aging - black, brown or grey will give different results. Then dry brush on the desired colour followed by a light layer of a lighter colour to highlight areas.
Final stage is weathering.
As with all buildings, I tend not to use the colours straight out of the tins unless it's for a base colour, try to vary the colours slightly by mixing in a touch of brown, grey or what ever colour before applying it to the model....
Hope that helps, Al.
