Ok guys so I am starting again as the boards I have used and the layout I had was not the right size so instead of having to match up 4 or more boards to get the size of board I need I have decided to start again.
Now what thickness should the base of the board Ideally be? I mean before the frame work goes on it of course. Is there a minimum or maximum thickness of the board which is acceptable that I can go for.
I'm planning on a 5x3ft layout on 1 board instead of several ones bolted together.
I'm still trying to work out what kind of plan for N gauge that is still Kato track that is simple but interesting modern british era but I do know that I want at least 3 ovals with the widest curve being 11" 45 degree curve on it and some sidings and at least 2 passing loops in the fiddle yard area so I can park stock up behind the scenes as well as some lines that join the mainlines on the front so I can store locos.
I have been looking at some plans online but they all seem pretty complicated when it comes to the sidings areas which is what I'm trying to avoid.
